Latest news: ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ----
Remote Install - Allison DOC, Transmission EPC, TCM Reflash
Allison DOC 2024.1 (with keygen) - $975
Allison DOC 2022 + Gen 6 data files 2023 - $145
Allison DOC 2019 - $95
Dealer diagnostic program for Allison automatic transmission control systems. Multilingual interface, Russian is present. It has built-in manuals for the construction of boxes and their control systems and troubleshooting guides.
For real operation, a diagnostic interface is required that is compatible with RP1210 and supports J1850, J1708/J1587, J1939 and ATEC protocols. Such as Nexiq USB-Link or Dearborn DPA-IV+. Interface drivers are attached.
[Image: Allison-DOC-2022-01-600x316.png]
Allison Transmission EPC - $175
Contents: Workshop Manuals, Service Bulletins-Service Manual, Technical Service Bulletins
[Image: allison-transmission-epc-kataloga-zapcha...59-big.jpg]
Allison TCM Reflash 3.5 - $45
Allison TCM Reflash provides worldwide customers accurate, reliable, and trackable calibrations for use with Allison Transmissions using WTEC II, CEC2, WTEC III, 1000 and 2000 Product Families TCMs (Pre-Allison 4th Generation Controls), Allison 4th Generation Controls TCMs, and EP 40/50 SystemsTM (Allison Electric DrivesTM).
[Image: Allison-TCM-Reflash-6-1.png]
Need it? Write to me for details
Thanks given by: VAXX88
Added Allison TCM Reflash 6.3 2021
(10-06-2021, 04:46 AM)olegka19 Wrote: In USA,you can get same set for 371$+local shipping.
Hi , i wrote you in PM
Added Allison DOC 2022
Allison DOC + TCM 2022 (with keygen)
Allison DOC 2024.1
