Latest news: ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ---- BMW ISTA 4.62.1x I-LEVEL OVERVIEW FULL ---- IVECO Power Trucks Buses EPC 2024 Full MEGA ---- IDA PRO 9.4 + KEYGEN FULL ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ----
Remote Install - Porsche Piwis II Piwis III, PET2, POSES, WDS, Manuals
Porshe
Porsche PIWIS III versions:
42.400 + 38.250 (Win 11) - $1430
42.000 + 38.250 (Win 11) - $399
41.600 + 38.250 (Win 10) - $370
41.300 + 38.250 (Win 10) - $350
40.900 + 38.250 (Win 10) - $330
40.600 (Win 10) or 40.400 + 38.200.17 - $299
40.400 or 38.200 + 39.500 + 39.900 - $249
40.0 or 38.200.17 or 38.400 or 39.500 (Win 8 or Win 10) or 39.700 or 39.500 + 38.200 or 38.900 + 38.250 or 39.700 + 38.400 - $199
38.200 - $99
39.900 - $75
Porsche PIWIS 3 Base of Firmwares
(old one) - $40
List of files of old PIWIS 3 Firmwares.
Each version on Acronis image and configured for VAS6154 clone or Porsche tool.
Updating VAS6154 clone to use it with PIWIS 3 - $299
If you have a problem with VAS6154 clone, when there is no license on VX Manager or it has 1.8 o never firmware, which
doesn't work with PIWIS 3. Write to me and I'll help to fix.
1. I'll give instruction, if your VAS can be be updated, you can pay and I'll next part of instruction.
2. All procedure takes around 48 hours (need to test VAS, make new licenses).
For it needs to have a Full HD screen (1920x1080) or on a virtual machine.
Porsche Piwis 3 has next languages: DE, GB, US, IT, ES, JP, ZH, RU, PR, NL.
Porsche Piwis III supported car list:
911: 992, 991, 997, 996, 996 GT2, 996 GT3, 993, 964
Boxster: 982, 981, 987, 986
Cayman: 982, 981, 987
Cayenne: 9YA, 9YA Campaign, 92A, 9PA
Panamera: 971, 970
Racing cars: 935, 991 GT2 RS Clubsport, 982 Cayman GT4 Clubsport, 981 Cayman GT4 Clubsport
Others: Macan, Taycan, 981 Spyder, Carrera GT, GT1, 968, 944, 928.
Video of some versions:
39.500 on Win 10 + 39.800 + 38.200
39.700
38.400
38.250 + 38.900
40.000
More details about versions:
38.200 Windows 8 x64
The most complete engineer (makes start-stop enable/disable offline until 2018)
Works poorly on K-line from 98-2008 (987 DME, 986 MAF, 996 DME and the like) (mediocre coverage of old cars from the PIWIS 1 program)
Model range coverage from 1998-2018
38.200.17 Windows 8 x64
What's new, if compare with 38.200
Improved communication with VCI
Update after 8888 days
38.250 Windows 8 x64
Full Engineer (updated online)
Works with K-line (good PIWIS 1 coverage)
Switching between versions 38.250 and 38.900 takes place inside the PIWIS program
38.400 Windows 8 x64
In engineering mode, you can no longer enable or disable the start-stop function
38.900 Windows 8 x64
Engineering features at level 39.400 with the Taycan
Updated online with the most complete engineer
Model range coverage from 1998-2020
Assembly works online with the original device 8888 days
On disk E there is an assembly of firmware up to 39.900 folder flashdaten
Switching between versions 38.250 and 38.900 occurs inside the PIWIS program
39.500 Windows 8 x64
More stripped down engineering functions compared to 38.400
Added support for new car models, including Taycan
Coverage of the car model range 1998-2020
Upgradeable from SDFlash
39.500 Windows 10 x64
Added to the image: a set of firmware from previous versions, PET2 with online update
39.700 Windows 8 x64
More stripped down engineering functions compared to 39.500
Works poorly on K-line (like 38.200) (mediocre PIWIS 1 coverage)
Added to the image: a set of firmware from previous versions, PET2 with online update and WDS 2017
Coverage of the car model range 1998-2018
39.800 Windows 8 x64
No engineering menu!
CFS search not working (offline guided troubleshooting) now only PPN online (dealer access required)
Online wiring diagrams (dealer access required)
Full functionality in V mode (dealer) (automatic offline programming and coding works, provided that there are offline files/firmware databases, but the firmware database can be purchased from me for $40)
39.900 Windows 8 x64
CFS search does not work (offline guided fault finding) now only PPN online
Wiring diagrams work
Full functionality in V mode (dealer) (automatic offline programming and coding works, provided that there are offline files)
Coverage from 1998-2020
40.000 Windows 8 x64
Dealer version full
Engineering features at 39.500 even better
Start-stop active and Sport plus
No coding for the latest Cayenne and Panamera
Macan encodings are present
There is a new car 935
Added 50 new firmwares for new cars
CFS and wiring work
Coverage of the car model range 1998-2021
PET2 8.0 with online update
Bases from previous versions can be purchased from us for $40
40.000 Windows 10 x64
Same specs as above, but installed on Win 10
40.400 Windows 8 x64
All modes work E, P, V
August version
New firmware, more than 100 pieces
Encodings, parameters
Doesn't ask for updates
An engineer in Taycan can do more
40.600 Windows 10 x64
Version from 10.2021
Engineering menu works
The ECU firmware has changed in automatic mode, now the blocks are determined automatically and the parameters are filled in with changes for a specific control unit automatically
There is a Porsche PET 8.0 633
40.900 + 38.250 Win 8 x64
Both versions work on 1 Windows
All modes work E, P, V, 38.250 All modes work E, P, V + Full Engineering
CFS 2021 (Fault Finding)
Porsche PET 8.0 (657 updates), free online updates
Database of new firmware and coding of Porsche Taycan and Cayenne E3
Wiring Diagram
PiUS
41.300 + 38.250 Win 10 x64
41.300 V/E modes, Full Engineering (1-st web version Piwis 4) + 38.250 V/E/P models, Full Engineering
For PT3G (V1, V2) or VAS6154 clone
Firmwares and coding for Taycan and E3 included
Porsche PET 8.0 (668 updates), free online updates
Wiring Diagram
PiUS
Piwis 41.400 + 38.350 Win 10 x64
41.400 V/E modes, Full Engineering + 38.250 V/E/P models, Full Engineering
for PT 3G (V1,V2) or Vas6154 clone
Last campaign for Taycan and E3 included
PPN service is available with this version.
Porsche PET 8.0 (682 update), free online updates
Wiring Diagram
PiUS
Piwis 41.600 + 38.250 Win 8 x64
41.600 V/E modes, Full Engineering + 38.250 V/E/P models, Full Engineering
for PT3G (V1, V2) or VAS6154 clone
Porsche PET 8.0 (693 update)
Wiring Diagram
PiUS
PIWIS 42.000 + 38.250 (Win 11)
This version has limitations when automatically programming units and running Campaign for cars 992, E3, Taycan, Panamera 971, new Macan
Notes for all versions:
  • Enabling additional functions and obtaining a programming code if dealer access is available.
  • The AirBag is readable only when the ignition is off.
  • Americans with shot pads don't count. And you cannot erase the crash date, only at the dealer.
  • PPN does not work with VAS6154
  • No version does not guarantee full coverage of all blocks for old cars as in PIWS 1. Therefore, for full support, you must use PIWIS 2 and Samtec VCI.
  • All Piwis versions with VAS6154 clone cannot encode the headlights due to the lack of baud rate of the VAS6154
  • Piwis 3 will work with VAS6154 clone with firmware 1.6.6.0, Porsche original tool or AllScanner tool.
Piwis 1 1998-2008
Piwis 2 2008-2016
Piwis 3 2016 -...
Porsche PIWIS II + configured for JLR Mongoose (Acronis image) - $149
Porsche Piwis allows you to read and erase DTC errors, process PCM data, record and then reproduce parameters and stills from sensors and ECUs, test individual actuators, encode electronic keys, program immobilizers. With this scanner, you can identify and eliminate errors in the engine, airbag control unit, climate control system, ABS and ASR systems, anti-theft system, pre-installed on the car.
Porsche PET2 2022 - $49
It's an electronic catalog that includes information on the original numbers of spare parts, accessories, and accessories for Porsche cars from 1950 to 2019 years of release.
Languages: English, French, Spanish, Portuguese, Deutsch, Japanese, Italian, Chinese, Dutch, Greece
Porsche POSES 2.42 - $45 (on VMware, because needs to have Win XP)
It's dealer information base on diagnostics and repair of cars Porsche, contains the detailed and full description of technology of repair, maintenance, diagnostics, bodywork, spare parts for guarantee replacement, etc. The program provides information on vehicles manufactured for the German and USA markets.
[Image: Porsche-Poses.jpg]
Porsche Technical Library + Wiring Diagrams + Workshop Manual + Parts Catalog - $210
Workshop Manual, Techinfo Library, Wiring Diagrams in English 2017.
Parts Catalog in German 1950-2018
[Image: Porsche-Technical-Workshop-WDS-Parts.jpg]
Porsche Cayenne E-Hybrid (9YA) V6-3.0L 2018-2020 Wiring Diagrams - $75
Porsche WDS 2017
- $35
The original wiring diagrams for the Porsche car brand, opened in its own interface, wiring diagrams Porsche removed from the diagnostic tool PIWIS.
VAG PETKA 8.3 EPC 01.2024 - $199
Parts catalog for VW, Seat, Skoda, Audi, Porsche, Trucks/Buses, Commercial vehicle.
Porsche PETKA 8.3 12.2024 - $145
Audi PETKA 8.3 12.2024 - $145
Need it? Write to me for details.
Added new versions: PIWIS 39.700, PET2 574
Added a new version - Porsche Piwis III 39.800
Added description of all versions and new kits:
Porsche PIWIS III 38.200 + 39.500 with online PET2 + 39.800
Porsche PIWIS III 38.400 + 39.700 with online PET2, WDS
Added the video with Piwis 39.500 on Win 10 + 39.800 + 38.200 on one system.
Added a new version - Piwis 39.900
Added description about Piwis 39.900
Added new version - Piwis 3 38.250 + 38.900, Porsche PET2 8.0 (594) 2021
Added the list of tools for Piwis 3: it'll work with VAS6154 clone with firmware 1.6.6.0, Porsche original tool, or AllScanner tool.
Added a new version - Porsche PIWIS III 40.000 and descriptions for PIWIS III 38.250 + 38.900
