Latest news: ---- Iveco Daily VI Electrical Wiring Diagram Full ---- BMW ISTA 4.61.40 Works ICOM D-CAN ENET FULL ---- Scania SDP3 v2.72.2 Files MEGA ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- BMW Passthru PTD Driver 3.0.14.0 TOOL ---- BMW ISTA 4.61.4x VERSION AND I-LEVEL OVERVIEW ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- PIWIS License Manager TOOL ---- TOYOTA ISTA OFFLINE LAUNCHER TOOL ---- Cummins Insite 8.9.0.130 + Keygen And Instruction ---- Scania SDP3 v2.72.1 Files MEGA ---- BMW ISPI ISTA 4.61.40 PATCH TOOL ---- Hex-Rays IDA Pro 9.4 HF + Patch Keygen ---- Node Ediabas Voltage Control 4.28.40 To 4.37.30 ---- ODIS-S COMPLETE LATEST FILES MEGA ---- Toyota TechStream Plus 2026.03.102 Diagnostic Software ---- Fendt Service Manuals Collection Mega ---- NCS Expert Daten TOOL ---- hi all ---- Node Ediabas Voltage Control Tool ---- DIAGBOX v9.260 FILES FULL MEGA ---- Piwis online ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ----
CAT FACTORY PASSWORDS GENERATOR 18 DIGIT
DUPA Offline
CAT
FULL CAT FACTORY PASSWORD 18 character pass generators
DUPA Offline
ALL REQEST SEND !!!
Thanks given by: Keganguew , DavinJOb
DUPA Offline
ALL REQEST SEND !!!
Thanks given by: Zippo1 , evo_per , Pocky
dnat43701 Offline
Thanks & Rep givin. May I please have the info? Thank you!!
Thanks given by: Galenot , RidgecokS , Keganguew , DavinJOb
DUPA Offline
ALL REQEST SEND !!!
Kiamicro Offline
Thanks given by: DavinJOb , RidgecokS , Galenot , Keganguew , petle
DUPA Offline
ALL REQEST SEND !!!
Thanks given by: DavinJOb , Galenot , Keganguew , RidgecokS , SMALI09
DUPA Offline
SAT2020
When you are in CAT ET you will go into WinFlash - it is an icon on the top of the screen that looks like an ecm with an arrow going into it. Once you are in WinFlash, you will choose a file using the browse button. There are flash file disks or you can get files on here for the application you are looking for. Once you choose the file then you click on the begin flash button. A status bar will come up telling you that the flash has begun and will move from 0% to 100%. Once the flash is complete a window will pop up asking what you want to do next. Choose RETURN TO CAT ET. It will then reload your information from the ecm. You MUST program the personality module (just above the FLS and FTS setting). Just choose to program it, the program will ask you if you are sure, choose yes. This is where you will need to use the keygen to make the password. If your keygen fails to make the right password, then you are stuck at that point. This is why you will have to flash it with a wash file first, then with the desired file that will get you past the three didget interlock code problem. It is done the same as described above.
Once you have completed the flash, always check your file by starting the truck and checking throttle response. You can flash an ecm and the truck will start and run, but with out the personality module being programed properly, you will have a dead pedal.
Any time you flash an ecm you should use a break out harness and go direct to the ecm, not through the data port as you can end up with corrupt files. I have had some older trucks where the flash would not go through the data port and would reject or freeze up half way through. Also it is much faster to use a break out harness.
Hope that answers your questions
DUPA Offline
ALL REQEST SEND !!!
dododkki Offline
it is there anyone test this 18 digits factory password calculator?
22 Guest(s)
