Latest news: ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ----
PTT Premium Tech Tool 2.8
DomoMc Offline
Volvo
Hi,
Has anyone got a copy of tech tool 2.8 developer? Price for single installs or with keygen please,
Thanks in advance!
DUPA Offline
2.8 Currently cannot be crack . because of Codemeter . and also all 2.8 version released now they are beta or they use 2.7 service in background mean actually they are not 2.8 . about 22 files use codemeter mean codemeter service must be run and also they use new protector AxProtector encrypts and all files are encrypt by This protection . so you must pass 2 protection one codemeter and second AxProtector . and you search google these protection are best in world German mind are behind it and cracking and multiple use of one account and all . already blocked . Chines and Russian Crackers works so much on this protection and license system but no success . if you can crack it you can get 15000.00 Euro from WIBU company .
Current version use the service 2.7 . mean background service are 2.7 Smile Mean something like fake . !
I know that there are so many bugs in it that they are going to roll it back again for an unknown time. There is a version in South America and Europe. I know nothing about it other than it is not in the U.S. I have seen and used 2.8 on a trail run and can tell you it is not worth your time to even mess with till a legit working version is out. It MIGHT do you some good on 2021's that is about it. However, there are enough patches to 2.7 to keep it going for awhile longer. If you want more cats out of the bag, I would stay with what is working. In about 1.5-2 years (projected) a whole new program will be rolling out. Built from the ground up. Lots more security that is going to use (I'm told) mulit levels of verification to access the server. In all fairness I know enough about a computer to find pornhub and check the weather.
Cheers!
Thanks given by: Jeffersonq99 , Geovane94
Truckdi Online
(05-27-2021, 12:59 PM)DomoMc Wrote: Hi,
Thanks in advance!
when the installation is real it is possible
DUPA Offline
no is not !!!
