Latest news: ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ----
Remote Install - Detroit DDDL, DDDE, Backdoor, DDEC, Manuals, EPC, Checksum Updater
Remote Install - Detroit Diesel Diagnostic Link DDDL, DDDE, Backdoor, DDEC, Manuals, EPC, Checksum Updater, Magic Tuner Flash Tool
Detroit Diesel Diagnostic Link DDDL 8.21 Full (Level 10 10 10) +Troubleshooting / Programming (with keygen locked 1 PC) - $1379
Detroit Diesel Diagnostic Link DDDL 8.20 2024 (Level 10 10 10) + 06.2023 Troubleshooting / Programming - $135
Detroit Diesel Diagnostic Link DDDL 8.20 (only activation) - $99
Detroit Diesel Diagnostic Link DDDL 8.13 SP3 (Level 10-10-10) MAX Edition + Backdoor - $135
This DDDL kit allow to increase the odometer value. This can only be done on those СPC software versions where it is possible to increase the odometer by regular way (i.e. ""Actions - Set Odometer"" menu is available)
DDDL 8.09 - $99
Program for diagnostics and firmware Detroit Diesel engines
[Image: Detroit-Diesel-Diagnostic-Link-DDDL.jpg]
Magic Tuner Flash Tool 3.0 (for Detroit, Maxxforce, Paccar, Caterpillar) - $135
Magic Tuner Flash Tool 2.1 (for Detroit, Maxxforce, Paccar, Caterpillar) (with keygen locked for 1 PC) - $465
Magic Tuner Flash Tool 2.1 (for Detroit, Maxxforce, Paccar, Caterpillar) - $115
Magic Tuner Flash Pro - $299
Included: Magic Tuner Flash Tool v1, v2.1, v2.2, Developer Tool v3, Pro Tool.
It works with:
Detroit MCM: EPA7, EPA10, GHG14, GHG17
Detroit ACM: EPA7, EPA10, GHG14, GHG17
MaxxForce: EDC17, EDC7, EIM7, S3V8, S4I6, S4V6, S4I60, S4I61, S4I6Special, S8V8, DCU, HICM, CECv10, ECMVW, NECM2, IDM2, NCEC1
Cummins: ECM, ACM
Vovlo: EMS2-2, EMS2-3
This tool can flash the ECU through the diagnostic connector so as not to remove the ECU, not to open, but simply flash them with a binary (*.bin) using any adapter, for example, Nexiq.
Works for:
  • Detroit MCM (EPA7, EPA10, GHG14, GHG17), ACM (EPA7, EPA10, GHG14, GHG17)
  • Maxxforce (EDC17, EDC7, EIM7, S3V8, S4I6, S4I6Special, NECM2, IDM2, S8V8)
  • Paccar
  • Caterpillar CAT AG
[Image: Magic-Tuner-Flash-Tool.jpg]
Detroit DD15 DPF, EGR, SCR Performance Tuning Files - $165
Files for delete parameters, manual transmission. There are 3 files for that work. These deletes are for units from 2010 to 2013.
Detroit DD13 DPF, EGR, SCR Performance Tuning Files - $165
Detroit DDEC IV - V Tuning files - $165
List of files.
Detroit DD15/S60 DPF EGR SCR Delete files - $165
Detroit Calibration Files - $99
Calibration Files Collection.
Detroit Diesel Calibration Tool DDCT 4.5 - $75
The DDC Cal Tool provides a programmable software interface to the Electronic Control Module (ECM) in an engine. Using the DDC Cal Tool, you can:
  • View and edit the control parameters in the ECM to optimize the control logic
  • View instrumentation variables, such as rpm or fluid temperatures and pressures, while the engine is running.
[Image: Detroit-DDCT.jpg]
Detroit Diesel Reprogramming System DDRS 7.11 - 75
Detroit Diesel Reprogramming System DDRS is a diagnostic program that is designed to schedule Detroit Diesel engines. It contains all data diagnostics and programming operations for all Detroit Diesel diesel engines. The main feature of it is that the application is an electronic tool for servicing the engine family EPA07, EPA10, GHG14 equipped with engines (S-60, MBE4000, MBE900, DD13, DD15, DD16).
[Image: Detroit-DDRS.jpg]
Detroit Diesel Drumroll Engineering DDDE - $39
Detroit Diesel Drumroll Engineering (DDDE) is a diagnostic software that includes:
  • View information about connected computers
  • Performing Standard DTC Operations
  • Performing standard and advanced troubleshooting methods
  • Reading the value of variables in real-time and their graphical display
  • Configure and manage settings
  • Performing service procedures.
[[Image: Detroit-Diesel-Drumroll-Engineering-DDDE.jpg]
Detroit Backdoor - $75
It is needed to unlock all the parameters.
[Image: Detroit-Backdoor.jpg]
Detroit DDEC Reports 9.03 - $115
Detroit DDEC Reports 9.01 - $35
DDEC Reports is a fleet management application that includes support for Detroit engine controllers: DDEC 3-5 ECU, VCU, CPC2, CPC02T, CPC04T, CPC302T, and CPC501T.
Detroit Diesel 60 Series Service Manual - $65
[Image: Detroit-Diesel-60-Series-Service-Manual.jpg]
Detroit Diesel ECU Checksum Updater 1.5 - $1639
It's a tool that updates the checksum of the ECU's specification files when we modify them. When you modify the file, you just have to drag it to the application and that's it. Otherwise, the DDDL will give you an error.
[Image: Detroit-Ecu-Checksum-Updater.jpg]
Detroit Diesel Power Service Literature Off-Highway - $85
Detroit Diesel Wiring Diagrams - $117
[Image: Detroit-Diesel-Wiring-Diagrams.jpg]
Detroit Diesel All Series Service Manual - $185
Detroit Full Set Shop Manual - $225
Contains: Workshop Manual, Repair Manual, Wiring Schematic, Service Bulletins, Parts Catalog
Added Detroit Diesel Calibration Tool DDCT 4.5, Detroit Diesel Reprogramming System DDRS 7.11
Added Detroit DD15/DD13 DPF, EGR, SCR Performance Tuning Files, Detroit Calibration Files.
Added DDDL 8.14 (Level 10) with Troubleshooting / Programming (with keygen 1 PC locked) and activation only.
Added Detroit Diesel All Series Service Manuals
Added Magic Tuner Flash Tool
DDDL 8.15 Full (Read 10 Write 10 Hardware Level 4) with Troubleshooting / Programming
DDDL 8.15 (only activation)
Added Detroit DD13/15/S60 DPF EGR SCR Delete files + DDEC IV - V Tuning files
DDDL 8.16 (with keygen locked 1 PC)
DDDL 8.16
and updated price on old version.
