Latest news: ---- Vediamo 5.1.1 + Activator Tactrix OpenPort 2.0 Full ---- Actros MP4 MP5 MANUALS ---- ZenZefi Certificates 23.11.2026 Full ---- Xentry Activation Working 2026 Windows 11 Full ---- Bosch ECU Database v0.3 Full ---- Bosch ECU Circuit Diagram EDC ---- DTS Monaco 9 Passthru Interface Configuration ---- Haynes Pro 2018 Virtual Box Full Mega ---- Komatsu manuals, anyone can share? ---- TOOL32 SERVICE HISTORY WITH EDIABAS EXTENSION ---- Introduktion ---- PCM Flash 1.20 Cleaned No Virus ---- PACCAR ESA COMPLETE + KEYGEN + SW FILES FULL ---- VCDS 25.3.2 + VIIPluslоader STM Arm ---- DTC Toyota Lexus Firmware Editor English ---- XENTRY 09.2026 FILES FULL ---- Immo Doctor v2.1.1 Full ---- How to Read an Electrical Schematic A Step by Step Guide ---- Tool32 Service History Generator Full ---- Hello from sweden ---- Automotive Software Complete With KG Collection Full ---- ToyoLex 3 + KG New Update ---- Renault Can Clip 237 Full Installation + KG 2024 ---- JLR PATHFINDER BOOK TRICKS AND SECRETS BOOK ---- Toyota Immo Remover Tool Full ---- MPPS 18 Clone ECU Remapping Software FULL ---- Chinese truck EOL fault codes ---- Sinotruk Automatic transmission training course ---- HardCut QLaunchr UtraCuttr HotStartr TunerCalc Vmaxr InfoGrabbr Collection Full ---- BMW ISTA Standalone 4.45 + Ediabas 7.3 FULL ----
Carly Pro 49.40 Full Unlocked All Car Brands (phone diagnostics)
I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.
Added a new version Carly Pro 46.18 All Car Brands
Thanks given by: Admin
Added a new version - Carly Pro 46.22 Full.
What's new:
- New codings for Audi, VW and BMW models 2007 - 2014
- New function for newer BMW models (starting roughly 2013): Engine Adaptation Reset
- Bugfixes for frozen Health checks
- Bugfixes for frozen application dashboard.
Thanks given by: Gh0sted10
Added a new version Carly All Car Brands 46.27.
Added a new version - Carly Pro 46.44 All Car Brands.
What's new:
Improved fault texts for newer VW, Audi, Seat & Skoda models (starting roughly 2014)
Coding for BMW G-models vastly improved: Video in motion, engine start stop memory added and much much more
Added a new version - Carly Pro 47.51 beta
Added a new version - Carly Pro 46.58
Added a new version - Carly Pro 46.63 + 50.04 beta
Added new version - Carly Pro 46.64. Whats new:
- All Carly brands in ONE app
- Fault information for BMW models between 2005 and 2020 improved with additional repair tips (only available for selective faults)
- Ford diagnostics now available as professional workshop level diagnostics! Carly will now show you the same error codes (incl. fault descriptions) as in a Ford workshop
- Improved fault texts and new parameter function for all supported Mercedes models
Added new version - Carly Pro 46.65
