Latest news: ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ---- VCM EDITOR COLLECTION FULL ---- VCDS Release 26.3.0 VIIPlus Loader 08.026.08 FULL ---- Winols 4.7 With Installer Full Mega ---- BMW CAS4+ EDITOR TOOL FULL ---- BMW ISTA 4.61.1x VERSION AND I-LEVEL OVERVIEW ---- ProSeCco Data Time Tool Full ---- CDA 6-J2534 bridge (Dubb45 Tool to use CDA with Passthru) ---- Subaru SSM4 Universal J2534 + Patch Full ---- Xentry Full Fix 4.9.8 Soft Easiest Installation Activation ---- Diagbox 7.57 Pack Complete Full ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 + Fix Last Update ---- GM ECU FLASHER TOOL FULL ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ---- BMW ISTA Czech Database 4.57.XX 4.61.XX MEGA ---- BMW ISTA+ 4.61.1x Files MEGA ---- BMW ISPI ISTA LAUNCHER 1.61.02.2059 MEGA ----
AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android
Alfa
AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android Patched
AlfaOBD is a software for the diagnostics of the vehicles produced by Fiat Chrysler Automobiles (FCA) group. Fiat / Alfa Romeo / Lancia, Chrysler / Dodge / Ram / Jeep. Although the software is primarily targeted for car owners, it provides many of the features of the professional scanners.
The software supported:
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
  • K-Line USB interface.
AlfaOBD features include:
  • monitoring various dynamic parameters of the body, dash, code, engine, gearbox, ABS, climate control, etc. and graphical presentation as adjustable plots.
  • reading of static data: ECU id, system status, fault codes with probable causes and environment information where applicable.
  • clearing fault codes, monitoring the system for the appearance of new faults.
  • active diagnostics and configuration procedures for various equipment controlled by engine, gearbox, body computer, climate control, ABS, airbag, code control, other ECUs. Service light reset, engine oil change, DPF regeneration and many more.
  • electronic key and RF remote control programming.
[img]I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.[/img]
Added a new version - AlfaOBD 2.1.9.6 (for Android) Patched
Added a new version - AlfaOBD 2.2.1.0 (for Android) Patched
Added new version AlfaOBD 2.2.5.0
Thanks given by: Kompel , Kompel , symace
Added new version AlfaOBD 2.3.5.0
(08-26-2022, 02:38 AM)raulinonog Wrote:
(06-24-2022, 07:49 PM)aleksey-ms Wrote: Adicionada nova versão AlfaOBD 2.3.5.0
Olá qual é a senha de descriptografia do download ????
Thanks given by: lindonato , ADMilstead , ADMilstead
Memoli Offline
(08-18-2020, 10:23 AM)aleksey-ms Wrote: Thank You !
Password please Smile
AlfaOBD 2.3.5.0 (for Android) Patched
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
[Image: AlfaOBD.jpg] [Image: AlfaOBD-.jpg]
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
Thanks given by: fasda1984 , fasda1984
fasda1984 Offline
mega pass please??
yabec2005 Offline
thanks please pass
