Latest news: ---- Zenzefi Aftersales Certificate 17.02.2027 + 26.11.2026 ---- Lsuite Checksum Tool Full ---- Kubota Service Manuals (FSM) Collection ---- DTS Monaco 8.16.015 Install + Patch + Keygen FULL ---- Multi Editor Honda 1.39.1.0.0 Full ---- Clone OpenPort 2.0 Windows 11 Driver ---- FTAG Checksums Test Fix TOOL ---- DTS Monaco 9.02 Install + Patch + Keygen FULL ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ---- Renault Can Clip 222 RTL2002 + Patch Full ---- Xentry Cars Passthru OpenShell 09.2026 Xus Das Wis Epc Starfinder Vediamo Monaco ---- VAG IMMO OFF TOOL NEW UPDATE ---- PCMflash Dongle Manager New Update ---- BMW Voltage Monitor TOOL ---- Global TechStream GTS+ Software ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ---- BMW ISTA 4.62.1x I-LEVEL OVERVIEW FULL ---- IVECO Power Trucks Buses EPC 2024 Full MEGA ---- IDA PRO 9.4 + KEYGEN FULL ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ----
VmWare AutoData 3.45 Last FREE FOR ALL
AutoData 4.35 Last in VMWare Win7Pro 32bit FREE FOR ALL
    Size 19GB total, 7GB archive (WinRAR)  No passwords needed!
AutoData 4.35 is a program for car services, includes information on auto repair, repair interval with a list of works, diagnostic data, lubricants and their volumes, electrical circuits, working diagrams.
Including data: Conditioners.  ABS. Belts, chains and timing gears. Engine management systems, component testing. Engine management. Control unit connectors. Key programming. Service indicators.
In general, this is exactly the program that any service station needs!
A virtual machine with a preinstalled program is a convenient tool for solving a necessary task.
The program is already installed and configured, no additional time and knowledge is required for tuning and optimization, you just turn on the Virtual Machine and work!
Best regards, SerJ-R !
Main windows:
[Image: 1-Main-Windows.png]
Program start and version:
[Image: 2-Program-Start.jpg]
Program work:
[Image: 3-Car-select.jpg]
[Image: 4-Data-Category-Choose.jpg]
[Image: 5-Tech-Data.jpg]
[Image: 6-Repair-Times.jpg]
[Image: 7-Wheel-Aligment.jpg]
[Image: 8-Timing-Belt.jpg]
[Image: 9-Service-Illustrations.jpg]
[Image: 10-Service-Shedules.jpg]
If you use my products, "Thanks" and "Reputation" are the best rewards!
dodge1977 Offline
It is not working, it says E0209 Sentinel key not found.
Thanks given by: bookini
(10-04-2021, 01:30 PM)dodge1977 Wrote: It is not working, it says E0209 Sentinel key not found.
Thanks!  I will check it on another PC and fix, if need.
a86anton Offline
Hi all.
Hi all.
I found the solution to the sentinel problem.
You must follow the steps to install the "SentinelDriver" program, and when it asks you if you can modify / repair / uninstall, choose the repair mode.
After restart it will work.
Thanks!
dodge1977 Offline
Hi all.
Hi all.
Thanks!
Where can we found " progit
Where can we found the "SentinelDriver" program ?
Yes I see onto many people have a problem with this VM.
I will correct this and re-upload VM again in some days.
Best regards
(10-10-2021, 07:13 AM)batya303 Wrote: Nagyon köszönöm és várom, de azt is tisztázni kell, hogy intel vagy amd host környezetben készült -e, mivel az illesztőprogram módosításai zavaróak lehetnek !!
My PC is Intel SkyLake I9  based, not AMD.
Virtual Machine is updated! Please try to use onto your PC! Best regards, Sergey!
dodge1977 Offline
Now it is good working, very good job.
Thank you.
Thanks given by: Prodrive , bookini , bookini
FILAT_TR Offline
Hello. Can you pls update link?
