Latest news: ---- EDC16 EEPROM Checksum Calculator TOOL ---- VAG TACHO 5.0 Read PIN Codes Program Keys ---- Inpa64 Tool64 And Update Ediabas To 7.7.2 ---- BMW ISTA 4.61.2x VERSION AND I-LEVEL OVERVIEW ---- DaVinci GOLD EDITION Activated ---- Mazda IDS 143.00 Files MEGA ---- Maxus 2024 SRS/Airbag ---- VOLVO PROSIS 08.2019 OFFLINE + ACTIVATION FULL ---- GDS2 KEYGEN FULL ---- JCB ServiceMaster 4 v23.2.7 + KG FULL ---- CEM VIN FINDER TOOL ---- D-Flash Eeprom Tool ---- New HPT File Editor 2026 v3.8.1 (+CTZ Converter) ---- DaVinci Deluxe Offline Edition 2025 Fully Unlocked Token ---- ECU TUNING SOLUTIONS FREE FOR ALL ---- BMW PSdZData 4.61.20 Version FULL ---- JLR Engineering Calculator TOOL ---- AUTOCOM DELPHI 2021 FILES FULL MEGA ---- Mercedes CAN Decoding New Update Tool ---- ECU Repair Guide New Update ---- Service Ranger Request ---- BMW HU Service Manager TOOL ---- BMW ISTA+ 4.61.20 Standalone FULL ---- XDecoder 12.7 Real Work + Activation ---- Porsche PIWIS 3 (Acronis Image) Offline Full ---- Porsche Piwis 3 v41.500 Full ---- VAG SGO EXTRACT MED17 MED9 EDC16 TOOL ---- HP Tuners 5.1.58 VCM Editor VCM Scanner FULL ---- DTS Monaco Projects Database 2015-2025 MEGA ---- BMW ISTA GUI 2.0.2 NEW UPDATE ----
Odis S 526 Odis E 11 Elsawin Etka VAG TPI VAG Dataflash VMware Image
estrika Offline
Audi
I share my Vmware VAG image
ODIS S 5.2.6
ODIS E 11
Elsawin last databases (except German ones)
Etka 8.3
VAG TPI 2018
Dataflash 01/2021
Configured to run with vas5054 Clone
Image size 126GB compressed 184gb uncompressed
Use 7zip no one uses winrar anymore
Can run in vmware 12 and above
Image configured as non persistent means that any changes done will be lost after shutdown, if you need to install something, first change this line in HDD.vmx
scsi0:0.mode = "independent-nonpersistent"
to
scsi0:0.mode = "independent-persistent"
DO NO INSTALL VMWARE TOOLS, the system is blocking the installation of vmware tools but i reinforce to not install it, odis engineering will stop working if vmware tools installed.
To search in vag TPI i installed agent ransack you just need to go to src folder and right click in the folder the option agent ransack will appear to pick and open program
user elsawin name GAD pass GAD if you want to create your own must change to mode persistent before and after go to elsa administration and create your user
elsa administrator is user admin pass admin
No password but you are welcome to thanks and rep
NOTE > some uefi bios computers will demand new registration of odis, for odis s 5.2.6 you can use the keygen and for odis e 11 you can request activation old cmos bios computers works fine as is.
Torrent file
Thanks given by: Admin , evans305
FLOOW Offline
The torrent does not start how can we do?
Thank you
