Latest news: ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ----
AlfaOBD PC v2.3.5.0 (2022) + Free Activation
[Image: 8a1.jpg]
New update: February 24th 2022: Version 2.3.5.0
Various fixes and improvements.
NOTE: .NET framework 4.0 or later required for the PC version to run.
AlfaOBD is a software for the diagnostics of the vehicles produced by Fiat Chrysler Automobiles (FCA) group. 1994-2021 Fiat / Alfa Romeo / Lancia cars, and 2005-2021 Chrysler / Dodge / Ram / Jeep cars are supported. Although the software is primarily targeted for car owners, it provides many of the features of the professional scanners.
AlfaOBD natively supports the Electronic Control Units (ECU) installed on the FCA group vehicles. The native support differs AlfaOBD from the OBDII / EOBD diagnostic applications providing a limited access to the engine and transmission modules and sometimes to the ABS.
The features of AlfaOBD
    monitoring various dynamic parameters of body, dash, code, engine, gearbox, ABS, climate control, etc. and graphical presentation as adjustable plots
    reading of static data: ECU id, system status, fault codes with probable causes and environment information where applicable
    clearing fault codes, monitoring the system for the appearance of new faults
    active diagnostics and configuration procedures for various equipment controlled by the ECUs. Service light reset, engine oil change, DPF regeneration and many more.
    electronic key and RF remote control programming
    adjustment of the car configuration with the ability to activate the newly installed equipment in the Body computer configuration, the Proxy alignment.
Installation
install alfaOBD PC
click on about
copy your license request code and post it here in the thread
finally copy the license file "Lic" that we provide and paste it in the installation folder.
Teppei1981 Offline
hello Prodrive,
Thanks for the software but I wanted to understand this software with which diagnostics is it compatible?
Thank you
Thanks given by: igorkeka91 , igorkeka91
The software requires a compatible OBD interface
nemesis3290 Offline
(03-16-2022, 03:05 PM)Prodrive Wrote: The software requires a compatible OBD interface
keygen please
keygen please
Copy your license request code and post it here in the thread
Thanks given by: ChinaWhell
Teppei1981 Offline
Excuse me, is it okay with the ELM 327 1.4 modified for fiat?
Teppei1981 Offline
I installed this software, the license request code is as follows:
BFE9FBFF000106C2
(03-26-2022, 10:58 PM)Teppei1981 Wrote: I installed this software,  the license request code is as follows:
BFE9FBFF000106C2
Thanks given by: Teppei1981 , Teppei1981 , Admin
Geovane94 Offline
send me keygen
(04-20-2022, 04:54 PM)Geovane94 Wrote: send me keygen
Thanks given by: talal , talal
