Latest news: ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ---- WinOLS 4.7 Latest Version Update ---- KESS K-SUITE 2.48 Latest Version Update ---- Hello From USA ---- ETKA 8.6 International English 01.06.2025 Virtualbox ---- Vediamo 5.1.1 + Activator Tactrix OpenPort 2.0 Full ---- Actros MP4 MP5 MANUALS ---- ZenZefi Certificates 23.11.2026 Full ---- Xentry Activation Working 2026 Windows 11 Full ---- Bosch ECU Database v0.3 Full ---- Bosch ECU Circuit Diagram EDC ---- DTS Monaco 9 Passthru Interface Configuration ---- Haynes Pro 2018 Virtual Box Full Mega ---- Komatsu manuals, anyone can share? ---- TOOL32 SERVICE HISTORY WITH EDIABAS EXTENSION ---- Introduktion ---- PCM Flash 1.20 Cleaned No Virus ---- PACCAR ESA COMPLETE + KEYGEN + SW FILES FULL ---- VCDS 25.3.2 + VIIPluslоader STM Arm ---- DTC Toyota Lexus Firmware Editor English ---- XENTRY 09.2026 FILES FULL ---- Immo Doctor v2.1.1 Full ---- How to Read an Electrical Schematic A Step by Step Guide ----
VAG DPF 3.40.12 Full (for Android device + ELM37)
VW
With this application you can find out if the filter is really in the process of regeneration, if the regeneration is awaiting completion, how many kilometers have you traveled since the last regeneration, etc.
Core functions:
  • Display of 12 DPF filter parameters like soot mass accumulation in the filter, regeneration duration, km traveled and time passed since last regeneration, EGR valve closing, exhaust gas temperatures of the inlet, and outlet of DPF (Attention: data shown may vary depending on the engine type due to the presence of the parameters into the engine ECU)
  • Manual or automatic parameters update
  • Display, for all the parameters, of the previous value and the difference between the actual and the previous value (only for automatic update delays different from 0 seconds)
  • Ability to exclude one or more parameter to increase the reading speed
  • Display of the filter filling percentage before reaching the filling limit that starts the execution of a field regeneration (standard regeneration controlled by the engine ECU)
  • Graphical display, using a progress bar, of the filling percentage value before starting a field regeneration or a service regeneration
  • Graphical display of the filter status: red filter for the regeneration phase (passive, field, or service) of the grey filter with different back internal areas depending on the filling percentage value
  • Display of extra data: adapter communication error counter, filter filling rating in µg/min, update time of all the 12 parameters, automatic update delay actually selected in the options menu
  • Notification bar icon to show an active connection and the auto-update process running.
[Image: VAG-DPF-3.3.jpg]
Added a new version - VAG DPF 3.18.8
What's new:
- added DAVA engine to group 15
- added CKFC engine to group 0
- added CRCA engine to group 17
Added new version VAG DPF 3.20.9 Full
Whats new:
-- correct an issue in group 18
Added new version VAG DPF 3.22.10
Added VAG DPF 3.25.10 Full
Added new version - VAG DPF 3.26.11
Added VAG DPF 3.27.12
Added VAG DPF 3.28.12 Full
marmavag Offline
(04-19-2021, 11:06 AM)aleksey-ms Wrote: Added a new version - VAG DPF 3.18.8
What's new:
passwd please
What's new:
passwd please
