Latest news: ---- Ford FJDS 133.01 + Patch Real Full ---- BMW ZGW CAN HACKER TOOL ---- BMW ISTA SQLiteDBs 4.58.30 PL MEGA ---- BMW ISTA GUI 2.1.0 New Update ---- VOLVO PTT 2.8.390 FILES INSTALLER MEGA ---- BMW ISTA+ 4.61.40 Standalone German English Full ---- Cummins Calterm Fix Tool ---- Eaton Service Ranger 4.2 + Keygen And Instruction ---- XDF A2L WinOLS Converter Tool FULL ---- Volvo APCI+ Database 09.2025 Files Mega ---- BMW Easy Connect 2 v1.5 TOOL ---- PIWIS3 VAS 6154 Clone Driver TOOL ---- WinOLS 5.67 ECU Tuning Hex Editor Tool ---- IMMO SERVICE TOOL 1.2 SOFTWARE 2017 + KEYGEN FULL ---- Iveco Daily VI Electrical Wiring Diagram Full ---- BMW ISTA 4.61.40 Works ICOM D-CAN ENET FULL ---- Scania SDP3 v2.72.2 Files MEGA ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- BMW Passthru PTD Driver 3.0.14.0 TOOL ---- BMW ISTA 4.61.4x VERSION AND I-LEVEL OVERVIEW ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- PIWIS License Manager TOOL ---- TOYOTA ISTA OFFLINE LAUNCHER TOOL ---- Cummins Insite 8.9.0.130 + Keygen And Instruction ---- Scania SDP3 v2.72.1 Files MEGA ---- BMW ISPI ISTA 4.61.40 PATCH TOOL ---- Hex-Rays IDA Pro 9.4 HF + Patch Keygen ---- Node Ediabas Voltage Control 4.28.40 To 4.37.30 ---- ODIS-S COMPLETE LATEST FILES MEGA ---- Toyota TechStream Plus 2026.03.102 Diagnostic Software ----
FREE - Newest version of PCM Hammer for GM PCMs
darkman5001 Offline
GM
PCM Hammer is a software tool that allows you to use a J2534 Pass-Thru device to flash GM PCMs for various GM engines.  It supports the vehicles listed below and can also be used to read and write to any one of the PCMs used in the vehicles below used in a hot rod or other application.
We are also developing a tuning program called Universal Patcher, which can currently already fully tune and calibrate all LS-based PCMs that PCM Hammer can read and write.
The latest version of Universal Patcher is also available for download.
Both of these programs are FREE, and open-source.  If you have an idea how we can improve it, or you and to help with development, contact us at the web site in the attached file.  They are in constant development to make them better and help the auto community and enthusiasts.
Those who use PCM Hammer to do FULL PCM reads, I ask you to please send me your .bin so that I can pass along to the developers on Universal Patcher to analyze to build memory mapping files so the tuner can become better and support more PCMs.
I am not the programmer of these programs.  I simply provide PCM circuit analysis and bench testing of the PCMs and software.  I take no credit for the amazing programming of these programs, just the pride in knowing I helped with development.
No passwords on these links.  Please give thanks + rep if I helped you.  Thank you.
PCM Hammer supports the following vehicles.  Will also work on other NON-USA GM brands using the same PCMs.
BRAVADA 02-04 Electronic Control Module; (LH engine)
ENVOY 02-04 Electronic Control Module; (LH engine)
ENVOY 05 Electronic Control Module; 4.2L (LH engine)
ENVOY XL 02-04 Electronic Control Module; 4.2L (LH engine)
ENVOY XL 05 Electronic Control Module; (LH engine), 4.2L
ENVOY XUV 04 Electronic Control Module; 4.2L (LH engine)
ENVOY XUV 05 Electronic Control Module; (LH engine), 4.2L
ISUZU ASCENDER 03-04 Electronic Control Module; (LH engine), 4.2L
ISUZU ASCENDER 05 Electronic Control Module; 4.2L (LH engine)
RAINIER 04 Electronic Control Module; 4.2L (LH engine)
RAINIER 05 Electronic Control Module; (LH engine), 4.2L
SAAB 9-7X 05 Electronic Control Module; (LH engine), 6 cylinder
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 12573576
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 12574976
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 12577955
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 12584593
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 16255757
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 19210065
TRAILBLAZER 02-05 Electronic Control Module; (LH engine)
TRAILBLAZER EXT 02-04 Electronic Control Module; 4.2L (LH engine)
TRAILBLAZER EXT 05 Electronic Control Module; (LH engine), 4.2L
CANYON 04-06 Electronic Control Module; (RH firewall)
COLORADO 04-06 Electronic Control Module; (RH firewall)
ENVOY 06 Electronic Control Module; 4.2L (LH engine)
ENVOY XL 06 Electronic Control Module; (LH engine), 4.2L
HUMMER H3 06 Electronic Control Module; (RH firewall)
ISUZU ASCENDER 06 Electronic Control Module; 4.2L (LH engine)
ISUZU I-280 06 Electronic Control Module; (RH firewall)
ISUZU I-350 06 Electronic Control Module; (RH firewall)
RAINIER 06 Electronic Control Module; (LH engine), 4.2L
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 12569773
SAAB 9-7X 06 Electronic Control Module; (LH engine), 6 cylinder, ID 12597521
TRAILBLAZER 06 Electronic Control Module; (LH engine), 4.2L
TRAILBLAZER EXT 06 Electronic Control Module; (LH engine), 4.2L
CANYON 07 Electronic Control Module; (RH firewall)
COLORADO 07 Electronic Control Module; (RH firewall)
ENVOY 07 Electronic Control Module; 4.2L (LH engine)
ENVOY 08 Electronic Control Module; 4.2L (LH engine), ID 19210067
HUMMER H3 07 Electronic Control Module; (RH firewall)
ISUZU ASCENDER 07 Electronic Control Module; (4.2L, LH engine)
ISUZU ASCENDER 08 Electronic Control Module; (4.2L, LH engine), ID 19210067
ISUZU I-290 07 Electronic Control Module; (RH firewall)
ISUZU I-370 07 Electronic Control Module; (RH firewall)
RAINIER 07 Electronic Control Module; (LH engine), 4.2L
SAAB 9-7X 07 Electronic Control Module; (LH engine), 6 cylinder
SAAB 9-7X 08 Electronic Control Module; (LH engine), 4.2L
TRAILBLAZER 07 Electronic Control Module; (LH engine), 4.2L
TRAILBLAZER 08 Electronic Control Module; (LH engine), ID 19210067
ASTRO 00-01 Electronic Control Module; (LH front by battery), ID 12200411
ASTRO 02 Electronic Control Module; (LH front by battery)
AVALANCHE 1500 02 Electronic Control Module; (LH front under battery)
AVALANCHE 2500 02 Electronic Control Module; (LH front under battery)
BLAZER S10/JIMMY S15 01-02 Electronic Control Module; (RH front engine compartment)
BRAVADA 01 Electronic Control Module; (RH front engine compartment)
CAMARO 01-02 Electronic Control Module; (behind RH strut tower), 5.7L, ID 12200411
CHEVROLET 3500 PICKUP 01-02 Electronic Control Module; (I-beam front axle only), gasoline (LH front engine compartment)
CORVETTE 01-03 Electronic Control Module; (RH engine compartment)
ESCALADE 02 Electronic Control Module; (LH front under battery), PCM
ESCALADE EXT 02 Electronic Control Module; (LH front under battery), PCM
EXPRESS 1500 VAN 01-02 Electronic Control Module; (LH rear engine compartment), ID 12200411
EXPRESS 2500 VAN 01-02 Electronic Control Module; (LH rear engine compartment), gasoline, ID 12200411
EXPRESS 3500 VAN 01-02 Electronic Control Module; (LH rear engine compartment), gasoline, ID 12200411
FIREBIRD 01-02 Electronic Control Module; (behind RH strut tower), 5.7L, ID 12200411
GMC 3500 PICKUP 01-02 Electronic Control Module; (I-beam front axle only), gasoline (LH front engine compartment)
S10/S15/SONOMA 01-02 Electronic Control Module; (RH front engine compartment), 4.3L
SAFARI (GMC) 00-01 Electronic Control Module; (LH front by battery), ID 12200411
SAFARI (GMC) 02 Electronic Control Module; (LH front by battery)
SAVANA 1500 VAN 01-02 Electronic Control Module; (LH rear engine compartment), ID 12200411
SAVANA 2500 VAN 01-02 Electronic Control Module; (LH rear engine compartment), gasoline, ID 12200411
SAVANA 3500 VAN 01-02 Electronic Control Module; (LH rear engine compartment), gasoline, ID 12200411
SIERRA 1500 PICKUP 01-02 Electronic Control Module; (LH front under battery)
SIERRA 2500 PICKUP 01-02 Electronic Control Module; (LH front under battery), gasoline
SIERRA 3500 PICKUP 01-02 Electronic Control Module; (LH front under battery), gasoline
SIERRA DENALI 02 Electronic Control Module; (LH front under battery)
SILVERADO 1500 PICKUP 01-02 Electronic Control Module; (LH front under battery)
SILVERADO 2500 PICKUP 01-02 Electronic Control Module; (LH front under battery), gasoline
SILVERADO 3500 PICKUP 01-02 Electronic Control Module; (LH front under battery), gasoline
SUBURBAN 1500 01-02 Electronic Control Module; (LH front under battery)
SUBURBAN 2500 01-02 Electronic Control Module; (LH front under battery)
TAHOE 01-02 Electronic Control Module; (LH front under battery)
YUKON 01-02 Electronic Control Module; (LH front under battery)
YUKON XL 1500 01-02 Electronic Control Module; (LH front under battery)
YUKON XL 2500 01-02 Electronic Control Module; (LH front under battery)
ASTRO 03 Electronic Control Module; (LH front by battery)
AVALANCHE 2500 03 Electronic Control Module; (LH front under battery)
BLAZER S10/JIMMY S15 03 Electronic Control Module; (RH front engine compartment)
CORVETTE 04 Electronic Control Module; (RH engine compartment), ID 12581565
CTS 04 Electronic Control Module; (RH engine compartment), Base, ID 12581565
EXPRESS 1500 VAN 03 Electronic Control Module; (LH rear engine compartment)
EXPRESS 2500 VAN 03 Electronic Control Module; (LH rear engine compartment)
EXPRESS 3500 VAN 03 Electronic Control Module; (LH rear engine compartment)
S10/S15/SONOMA 03 Electronic Control Module; (RH front engine compartment), 4.3L
SAFARI (GMC) 03 Electronic Control Module; (LH front by battery)
SAVANA 1500 VAN 03 Electronic Control Module; (LH rear engine compartment)
SAVANA 2500 VAN 03 Electronic Control Module; (LH rear engine compartment)
SAVANA 3500 VAN 03 Electronic Control Module; (LH rear engine compartment)
SIERRA 1500 PICKUP 03 Electronic Control Module; (LH front under battery), w/4.3L
SIERRA 2500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 8.1L
SIERRA 3500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 8.1L
SILVERADO 1500 PICKUP 03 Electronic Control Module; (LH front under battery), w/4.3L
SILVERADO 2500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 8.1L
SILVERADO 3500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 8.1L
SUBURBAN 2500 03 Electronic Control Module; (LH front under battery), 8.1L
YUKON XL 2500 03 Electronic Control Module; (LH front under battery), 8.1L
AVALANCHE 1500 03 Electronic Control Module; (LH front under battery)
AVALANCHE 1500 04 Electronic Control Module; (LH front under battery), ID 12602802
AVALANCHE 1500 05-06 Electronic Control Module; (LH front under battery)
ENVOY XL 03 Electronic Control Module; 5.3L (next to air box)
ESCALADE 03 Electronic Control Module; (LH front under battery), PCM
ESCALADE 04 Electronic Control Module; (LH front under battery), ID 12602802
ESCALADE 05-06 Electronic Control Module; (LH front under battery)
ESCALADE ESV 03 Electronic Control Module; (LH front under battery), PCM
ESCALADE ESV 04 Electronic Control Module; (LH front under battery), ID 12602802
ESCALADE ESV 05-06 Electronic Control Module; (LH front under battery)
ESCALADE EXT 03 Electronic Control Module; (LH front under battery), PCM
ESCALADE EXT 04 Electronic Control Module; (LH front under battery), ID 12602802
ESCALADE EXT 05-06 Electronic Control Module; (LH front under battery)
HUMMER H2 03 Electronic Control Module; (LH front under battery)
HUMMER H2 04 Electronic Control Module; (LH front under battery), SUV
HUMMER H2 05-06 Electronic Control Module; (LH front under battery)
HUMMER H2 07 Electronic Control Module; (LH front under battery), powertrain control
ISUZU ASCENDER 03 Electronic Control Module; (LH engine), 5.3L
SIERRA 1500 PICKUP 03 Electronic Control Module; (LH front under battery), w/o 4.3L
SIERRA 1500 PICKUP 04 Electronic Control Module; (LH front under battery), w/o hybrid option; w/o 4.3L; ID 12602802
SIERRA 1500 PICKUP 05-06 Electronic Control Module; (LH front under battery), w/o hybrid option; w/o 4.3L
SIERRA 1500 PICKUP 07 Electronic Control Module; classic style (creased door skin), (LH front under battery), w/o hybrid option; w/o 4.3L
SIERRA 2500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SIERRA 2500 PICKUP 04 Electronic Control Module; (LH front under battery), gasoline, 6.0L, ID 12602802
SIERRA 2500 PICKUP 05-06 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SIERRA 2500 PICKUP 07 Electronic Control Module; classic style (creased door skin), (LH front under battery), gasoline, 6.0L
SIERRA 3500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SIERRA 3500 PICKUP 04 Electronic Control Module; (LH front under battery), gasoline, 6.0L, ID 12602802
SIERRA 3500 PICKUP 05-06 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SIERRA 3500 PICKUP 07 Electronic Control Module; classic style (creased door skin), (LH front under battery), gasoline, 6.0L
SIERRA DENALI 03 Electronic Control Module; (LH front under battery)
SIERRA DENALI 04 Electronic Control Module; (LH front under battery), ID 12602802
SIERRA DENALI 05-06 Electronic Control Module; (LH front under battery)
SIERRA DENALI 07 Electronic Control Module; classic style (creased door skin), (LH front under battery)
SILVERADO 1500 PICKUP 03 Electronic Control Module; (LH front under battery), w/o 4.3L
SILVERADO 1500 PICKUP 04 Electronic Control Module; (LH front under battery), w/o hybrid option; w/o 4.3L; ID 12602802
SILVERADO 1500 PICKUP 05-06 Electronic Control Module; (LH front under battery), w/o hybrid option; w/o 4.3L
SILVERADO 1500 PICKUP 07 Electronic Control Module; classic style (creased door skin), (LH front under battery), w/o hybrid option; w/o 4.3L
SILVERADO 2500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SILVERADO 2500 PICKUP 04 Electronic Control Module; (LH front under battery), gasoline, 6.0L, ID 12602802
SILVERADO 2500 PICKUP 05-06 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SILVERADO 2500 PICKUP 07 Electronic Control Module; classic style (creased door skin), (LH front under Battery), gasoline, 6.0L
SILVERADO 3500 PICKUP 03 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SILVERADO 3500 PICKUP 04 Electronic Control Module; (LH front under battery), gasoline, 6.0L, ID 12602802
SILVERADO 3500 PICKUP 05-06 Electronic Control Module; (LH front under battery), gasoline, 6.0L
SILVERADO 3500 PICKUP 07 Electronic Control Module; classic style (creased door skin), (LH front under battery), gasoline, 6.0L
SSR 03 Electronic Control Module; (next to air box)
SUBURBAN 1500 03 Electronic Control Module; (LH front under battery)
SUBURBAN 1500 04 Electronic Control Module; (LH front under battery), ID 12602802
SUBURBAN 1500 05-06 Electronic Control Module; (LH front under battery)
SUBURBAN 2500 03 Electronic Control Module; (LH front under battery), 6.0L
SUBURBAN 2500 04 Electronic Control Module; (LH front under battery), 6.0L, ID 12602802
SUBURBAN 2500 05-06 Electronic Control Module; (LH front under battery), 6.0L
TAHOE 03 Electronic Control Module; (LH front under battery)
TAHOE 04 Electronic Control Module; (LH front under battery), ID 12602802
TAHOE 05-06 Electronic Control Module; (LH front under battery)
TRAILBLAZER EXT 03 Electronic Control Module; 5.3L (next to air box)
YUKON 03 Electronic Control Module; (LH front under battery)
YUKON 04 Electronic Control Module; (LH front under battery), ID 12602802
YUKON 05-06 Electronic Control Module; (LH front under battery)
YUKON XL 1500 03 Electronic Control Module; (LH front under battery)
YUKON XL 1500 04 Electronic Control Module; (LH front under battery), ID 12602802
YUKON XL 1500 05-06 Electronic Control Module; (LH front under battery)
YUKON XL 2500 03 Electronic Control Module; (LH front under battery), 6.0L
YUKON XL 2500 04 Electronic Control Module; (LH front under battery), 6.0L, ID 12602802
YUKON XL 2500 05-06 Electronic Control Module; (LH front under battery), 6.0L
