Latest news: ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ----
(12-11-2022, 11:39 PM)Jem@prog Wrote:
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 128.02 + FJDS 128.01 + FDRS 34.5.1 + Mazda IDS 127 - for VCM2 / J2534
Activation?
I can help, I sent you a PM.
Added Ford FDRS 34.5.3
Aylin28 Offline
aleksey-ms
Thanks, PM for pass
Thanks given by: ADMilstead , ADMilstead
(12-23-2022, 05:04 PM)Aylin28 Wrote: aleksey-ms
Thanks, PM for pass
Added Mazda IDS 128
Added Ford IDS 128.04
Aylin28 Offline
aleksey-msFord IDS 128.04 + FJDS 128.01 + FDRS 34.5.3 + Mazda IDS 128 - for VCM2 / J2534
IDS. IDS provides complete dealership level vehicle diagnostic coverage for all 1996 to select 2018 Ford, Lincoln, Mercury vehicles. IDS requires the use of Ford diagnostic hardware including VCM, VCM II, and VCMM devices. The IDS software license includes time-based access to the plete dealership level diagnostic software for all 2018 to present Ford and Lincoln vehicles. FJDS is designed for use with J2534 compatible Vehicle Communications Interfaces (VCI) including Ford diagnostic hardware (VCM II, or VCMM). The FJDS software license includes time-based access to the FJDS software, software updates, and calibration files.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass. Thank YOU PASS PLEASE
(01-15-2023, 07:00 PM)Aylin28 Wrote: aleksey-msFord IDS 128.04 + FJDS 128.01 + FDRS 34.5.3 + Mazda IDS 128 - for VCM2 / J2534
Illoolli Offline
Pass Please Thank You
(01-16-2023, 08:33 AM)Illoolli Wrote: Pass Please Thank You
