Latest news: ---- RENAULT DDT2000 FILES COLLECTION MEGA ---- KIA HYUNDAI DTC EDITOR + KEYGEN ---- KIA Variant Codes Files Pack ---- BMW PSdZData 4.60.42 Files FULL ---- MAN KEY CATS TOOL ---- HYUNDAI KIA GDS SOFTWARE FULL ---- John Deere Service Advisor 5.3 2025 ---- HPT To BIN Converter + Keygen ---- MERCEDES SKCV CALC TOOL ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ---- WinOLS 4.7 Latest Version Update ---- KESS K-SUITE 2.48 Latest Version Update ---- Hello From USA ---- ETKA 8.6 International English 01.06.2025 Virtualbox ---- Vediamo 5.1.1 + Activator Tactrix OpenPort 2.0 Full ---- Actros MP4 MP5 MANUALS ---- ZenZefi Certificates 23.11.2026 Full ---- Xentry Activation Working 2026 Windows 11 Full ---- Bosch ECU Database v0.3 Full ---- Bosch ECU Circuit Diagram EDC ---- DTS Monaco 9 Passthru Interface Configuration ---- Haynes Pro 2018 Virtual Box Full Mega ---- Komatsu manuals, anyone can share? ----
toyolex3 for toyota and lexsus editing !!
yousef9371 Offline
ECU List SUPPORT :
– Supports Generation 1, 2 and 3 files from Toyota and Lexus Denso ECUs for DTC erase function and special
functions, on Diesel, Gasoline and Hybrid engines.
– New algorithm that recognizes Generation 3 DTC tables structure embedded in Denso Generation 2 files.
– Added new algorithm that allow DTC erase function also on Hybrid engine vehicles.
– Adblue / SCR System disable function.
– DieselParticulate Filter [DPF] disable function for all Denso Generations ECUs.
– Vehicle speed limiter [Vmax] correction function for 1GD-FTV, 2GD-FTV, 1KD-FTV and 2KD-FTV Diesel engines.
– Catalyst System [CAT – Lambda sensor] disable function for 1GD-FTV and 2GD-FTV diesel engines.
– Catalyst System [CAT – Lambda sensor] disable function for all gasoline engines.
– Exhaust Gas Recirculation [EGR] disable function.
– Intake Manifold Valve [IMV] disable function.
– Intake Manifold Runner [IMR] disable function.
– Immobilizer disable function [IMMO OFF] on 1KD-FTV, 2KD-FTV, 1GD-FTV and 2GD-FTV with Denso GEN 2 ECUs .
– Automatic file Generation recognition feature that simplifies the selection process of the function to launch.
Frequently Asked Questions:
Q: What generations of Denso ECUs does ToyoLex 3 support?
A: ToyoLex 3 supports binary files of all 3 generations of Toyota and Lexus Denso Engine Control Units on the market, gasoline, diesel and hybrid engines.
Q: Which flash tools support files from?
A: ToyoLex 3 supports binary files from the following flashing tools:
– KTAG.
– New Trasdata.
– New Genius.
– Kess.
– BitBox.
– VF 2 Flasher.
– Flex by Magic MotorSport.
– ECUF Flasher by Alex.
– PCM Flasher.
– Toyota Lexus ECU Flasher.
Q: ToyoLex 3 works with a physical interface?
A: ToyoLex 3 is an application whose function is to automatically edit binary files from ECUs, therefore it does not require any interface.
Q: Does ToyoLex 3 support .CUW calibration files?
A: ToyoLex 3 supports only binary files (.bin). We offer a .cuw to .bin file conversion service if necessary.
Q: What family of microcontrollers does ToyoLex 3 support?
A: ToyoLex 3 supports binary files from the following microcontrollers:
– Denso Generation 3: R7F701202 AND R7F701216 (4Mb Flash).
– Denso Generation 2: D76F0199GD (1.25Mb Flash), D76F0196F1 (1.5Mb Flash), D76F0219F1 (2.0Mb Flash).
– Denso Generation 1: NEC 76F00XX series (368 Kb, 512 Kb, 736 Kb, 768 Kb, 992 Kb, 1Mb Flash).
1 pc 30 usd
paypal accept
pm for more details
josepapel Offline
Best seller, Youssef
zanzy75 Offline
(02-02-2023, 12:02 AM)yousef9371 Wrote: SUPPORTO ELENCO ECU:
– Supporta i file di Generazione 1, 2 e 3 delle ECU Denso Toyota e Lexus per la funzione di cancellazione DTC e
funzioni speciali, su motori Diesel, Benzina e Ibridi.
– Nuovo algoritmo che riconosce la struttura delle tabelle DTC di Generazione 3 incorporata nei file Denso di Generazione 2.
– Aggiunto un nuovo algoritmo che consente la funzione di cancellazione DTC anche sui veicoli con motore Ibrido.
– Funzione di disattivazione del sistema AdBlue/SCR.
– Funzione di disattivazione del filtro antiparticolato diesel [DPF] per tutte le ECU Denso di Generazione.
– Funzione di correzione del limitatore di velocità del veicolo [Vmax] per i motori Diesel 1GD-FTV, 2GD-FTV, 1KD-FTV e 2KD-FTV.
– Funzione di disattivazione del sistema catalizzatore [CAT – Sonda lambda] per i motori diesel 1GD-FTV e 2GD-FTV.
– Funzione di disattivazione del sistema catalizzatore [CAT – Sonda lambda] per tutti i motori a benzina.
– Funzione di disattivazione del ricircolo dei gas di scarico [EGR].
– Funzione di disattivazione della valvola del collettore di aspirazione [IMV].
– Funzione di disattivazione del collettore di aspirazione [IMR].
– Funzione di disattivazione dell'immobilizzatore [IMMO OFF] su 1KD-FTV, 2KD-FTV, 1GD-FTV e 2GD-FTV con centraline Denso GEN 2.
– Funzione di riconoscimento automatico della generazione dei file che semplifica il processo di selezione della funzione da avviare.
Domande frequenti:
D: Quali generazioni di centraline Denso supporta ToyoLex 3?
R: ToyoLex 3 supporta i file binari di tutte e 3 le generazioni di centraline motore Denso Toyota e Lexus sul mercato, motori a benzina, diesel e ibridi.
D: Quali strumenti di flashing supportano i file?
R: ToyoLex 3 supporta i file binari dei seguenti strumenti di flashing:
– KTAG.
– New Trasdata.
– New Genius.
– Kess.
– BitBox.
– VF 2 Flasher.
– Flex di Magic MotorSport.
– ECUF Flasher di Alex.
– PCM Flasher.
D: ToyoLex 3 funziona con un'interfaccia fisica?
R: ToyoLex 3 è un'applicazione la cui funzione è quella di modificare automaticamente i file binari dalle centraline, quindi non richiede alcuna interfaccia.
D: ToyoLex 3 supporta i file di calibrazione .CUW?
R: ToyoLex 3 supporta solo file binari (.bin). Offriamo un servizio di conversione da file .cuw a .bin, se necessario.
D: Quale famiglia di microcontrollori supporta ToyoLex 3?
R: ToyoLex 3 supporta i file binari dei seguenti microcontrollori:
– Denso Generazione 3: R7F701202 E R7F701216 (4 Mb Flash).
– Denso Generazione 2: D76F0199GD (1,25 Mb Flash), D76F0196F1 (1,5 Mb Flash), D76F0219F1 (2,0 Mb Flash).
– Denso Generazione 1: serie NEC 76F00XX (368 Kb, 512 Kb, 736 Kb, 768 Kb, 992 Kb, 1 Mb Flash).
1 pz 30 USD
PayPal accetta
messaggi privati per maggiori dettagli
BUONGIORNO SARE INTENZIONATO AD ACQUISTARE TOYOLEX3..GRAZIE
