Latest news: ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ----
Added Ford IDS 129.03
Added Ford FDRS 35.5.4
Thanks given by: jackm44 , jackm44
VTrifonov Offline
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 129.03 + FJDS 129.01 + FDRS 35.5.4 + Mazda IDS 129 - for VCM2 / J2534
Hello, can I have the password (I gave you Thanks and Rate (Reputation))
ECARFRANCE Offline
#95
(11-26-2020, 02:09 PM)thank you for sharing can you give me the password pleasealeksey-ms Wrote: Ford IDS 129.03 + FJDS 129.01 + FDRS 35.5.4 + Mazda IDS 129 - for VCM2 / J2534
gltcls8 Offline
Ford
(11-26-2020, 02:09 PM)阿列克谢-MS Wrote: 福特 IDS 129.03 + FJDS 129.01 + FDRS 35.5.4 + 马自达 IDS 129 - 适用于 VCM2 / J2534
IDS。IDS为所有1996年选择的2018年福特,林肯,水星车辆提供完整的经销商级车辆诊断服务。IDS需要使用福特诊断硬件,包括VCM,VCM II和VCMM设备。IDS 软件许可证包括对 IDS 软件、软件更新、校准文件的基于时间的访问。
FJDS提供涵盖1996年选择2018年福特、林肯和水星模块重新编程功能的模块重新编程软件,以及适用于所有2018年福特和林肯车辆的完整经销商级诊断软件。FJDS设计用于J2534兼容的车辆通信接口(VCI),包括福特诊断硬件(VCM II或VCMM)。FJDS 软件许可证包括对 FJDS 软件、软件更新和校准文件的基于时间的访问。
FDRS - 福特汽车公司的下一代工厂车辆诊断软件,设计用于兼容 VCM II、VCMM 和 J2534 的 VCI。FDRS为一些2018年和未来的车辆提供完整的经销商级车辆诊断保险。FDRS 提供卓越的功能,更加用户友好,并提供比 IDS 更多的诊断工具。基于云的系统确保每次FDRS登录福特网络时都能为技术人员提供最新的软件。
需要吗?按钮 评价 (声誉) 和 谢谢, 下午 通过。
Added Ford IDS 129.04
Added Ford FDRS 35.5.5
Added Ford IDS 129.05
Thanks given by: LOUISe , LOUISe , Thomasten
crutchcom, 7 Guest(s)
