Latest news: ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ---- Automatic Transmission Repair Manuals Rebuild Parts ---- BMW ISPI ISTA Launcher Offline Version MEGA ---- Bosch ESI [tronic] 2014 DVD1+DVD2+DVD3 Diagnostic Software ---- L-Suite Checksum Tool 1.03 Full Pack With KSuite DLLs ---- Actia Multidiag J2534 PassThru Support Full ---- hello from norway ---- Cummins Insite 9.3.0.22 Files Mega ---- SWFinder 6.1.8 File MEGA ---- ISTA iLean Voltage 4.61.40 No License No ISPI Admin Client ---- BMW ETK Price 10.2026 ---- Multi Editor Honda Tool Full ---- ECU Circuit Diagram Bosch Schematic ---- BMW FSC GENERATOR MG1 MD1 MSD DME TOOL ---- Wabco Calculator PIN1-PIN2 Activator Keygen ---- BMW Immo Off BTT EWS Deleter v1.1 Immobilizer TOOL ---- Alex Flasher + Keygen Full Version ---- Nexiq Etech 2.13 Setup File Needed ---- BMW ISTA Ilean 4.61.40 VOLTAGE PATCH TOOL ---- ATRIS Stahlgruber + Technik 2018 VM FULL ---- BMW ISTA VOLTAGE PATCH TOOL ----
TOYOTA KIA HYUNDAI DTC OFF EDITOR + ACTIVATION
cki30 Offline
(03-31-2023, 04:51 PM)serg1970 Wrote: Hello,
does not work. I unpacked the activation file into the folder with the program, and still asks for activation.
Safengine
This license file has been locked to a different machine.
Current Hardware ID:
1+LKtQAIEACpBgMAipo+Vy1MBges0TSVQOQ/sA==
(Press Ctrl+V to paste)
ОК
Thank you!
Same here, tried with two  keys, did you solved the problem?
I run w10 64bit, DaVinci,VCDS... works fine on this machine.
Help anyone?
Safengine
yK/BrQAIBgAgD2AAvGD204viBgdGdLOoWVaKTw==
OK
Second key does not work, i can try on different computer
Thanks
serjikel Offline
#42
Hello. Activate please:
1+LKtQAIEADjBgQAVPTvvY8EBgelLtjC430fcw==
Safengine
ОК
Thank you!
Help anyone?
Safengine
OK
Thanks
(03-31-2023, 10:13 PM)serjikel Wrote: Hello. Activate please:
Thanks given by: serjikel , cki30 , cki30
cki30 Offline
It works fine on another pc
Thanks!
serg1970 Offline
#45
Hi,
please activate:
Safengine
1+LKtQAIEACnBgIAONmr3F4/Bgch+c9Z4FZzuw==
ОК
Thank you!
(04-01-2023, 03:28 PM)serg1970 Wrote: Hi,
please activate:
Safengine
ОК
Thank you!
moory565 Offline
Hardware ID:
1+LKtQAIEADjBgQAYpCfcRRgBgc4QgetpY+xJA==
Thanks for everything, you are awesome
(04-06-2023, 02:48 AM)moory565 Wrote: Hardware ID:
moory565 Offline
thanks alot
my regards
Gnoppix Offline
1+LKtQAIEADqBggAWM4x/llcBgcqgmMvGw9yUg==
thnx in advance
8 Guest(s)
