Latest news: ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ----
VAG ODIS-Service 7.2.1+ODIS-Engineering 12.2 set up and activated (Acronis Legacy+UEF
ELSAWIN
VAG ODIS-Service 7.2.1+ODIS-Engineering 12.2 set up and activated (Acronis Legacy+UEFI)
Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
Questions about the password, write in a personal.Asking for a password in a topic will be ignore.
 [Image: vag_logo.jpg]
Acronis correctly creates and restores UEFI bootloaders without additional steps to repair them.
  • Year / Release date: 2021
  • System requirements: 60 Gb HDD or SDD, 4GB RAM
  • Interface language: Multilingual (English by default)
  • Activator: present
  • Description: Acronis Windows 10 LTSC x64 ENGLISH disk image, contains both Legacy and UEFI boot loaders image of programs for diagnostics, coding and programming of cars.
       + Strelec WinPE
       + Rufus
  • Add. Information: The image contains EVERYTHING you need to set up for FULL FUNCTIONALITY!
    Folder for binding to the device: c:\windows\config" (password: fantomel).
 Devices that support these programs:
  • PassThru J2534 devices
  • VAS 5054 (original and clone)
  • VAS 6154 (original and clone)
[Image: images?q=tbn:ANd9GcQwmwtm5Na20i6JAMsFKld...Q&usqp=CAU]
ODIS-Service 7.2.1 is a dealer software for diagnostics of VAG-group cars, which was developed to replace the good old VAS PC. The ODIS program works with all the latest vehicles and can adapt, code and adjust the control units of these vehicles.
ODIS-Engineering 12.2 - allows you to "flash" control units without official access to the server. To do this, simply specify the file with the desired firmware. ODIS Engineering also allows you to change encodings and adaptations. But there is no guided diagnostics in the engineering ODIS, it is available only in the ODIS Service.
If you need it - write to us!
Changing the archive content and password. For those partners who downloaded before 12/02/2023, you need to download again and do these steps again. After you click button Rep (Reputation) + Thanks on the thread, i will send you a password.
Thanks given by: ELI47
