Latest news: ---- BMW Voltage Monitor TOOL ---- Global TechStream GTS+ Software ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ---- BMW ISTA 4.62.1x I-LEVEL OVERVIEW FULL ---- IVECO Power Trucks Buses EPC 2024 Full MEGA ---- IDA PRO 9.4 + KEYGEN FULL ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ----
citroen c1 auto box config
stevec1 Offline
Citroen
i am trying to do a a re-learn on a citroen c1 semi auto gearbox, apart from using the diagbox software, can anyone recommend another program to do the re-learning after the clutch replacement, delphi does not give me the option and i dont currently have the hardware box for the psa diagbox software.
Thanks given by: Galenot , RidgecokS , fabry7768 , Shaikh , Nidzoba , hoschi001
dyann10123 Offline
Hello this method work without diagnostic system, all manually, but sorry i have only the document in french:
- mettre en position 'N'
- couper le contact
- il faut shunter les contact TC (13) et CG (4) de la prise obd
diagnostic
- attendre 10 secondes minimum
- mettre le contact
- enfoncer la pédale de frein au moins 7 fois en 3 secondes
- un signal sonore retentit 2 fois espacés de 0.25s
- avec le levier de vitesse : composez les séquences suivantes avec le pied maintenu enfoncé sur le frein.
initialisation de l'ECU :
N E M - M - M - M - E N
initialisation de l'embrayage :
N E M + M - M + M - E N
initialisation de la boîte de vitesse :
N E M - M - M + M + E N
- relâcher le frein
- enfoncer le frein une fois
- le signal sonore retentit ( intervalle de 2.5s entre chaque
réglage ou initialisation).
initialisation de l'ECU : deux bip espacés de 0.5s
initialisation de l'embrayage : trois bis espacés de 0.5s
initialisation de la boîte de vitesse : quatre bips espacés de 0.5s
Si vous n'entendez pas les bips : recommencez 15s au moins après avoir coupé le contact.
- pour finir : enfoncer la pédale de frein 3 fois dans un lap de 2s
- deux bips espacés de 0.25s retentissent
- couper le contact et attendre 10s
- débrancher le shunt
Thanks given by: Rafai999 , daryn41
