Latest news: ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ----
Added Ford FDRS 37.4.7
Added Ford IDS 130.01 + FJDS 130.01
annguyenvu Offline
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 130.01 + FJDS 130.01 + FDRS 37.4.7 + Mazda IDS 129 - for VCM2 / J2534
PLEASE PASS SIR
PLEASE PASS SIR
Thanks given by: argegsm
Added Mazda IDS 131
fabiroz Offline
#136
(11-26-2020, 02:09 PM)Aleksey-MS Wrote: Ford IDS 130.01 + FJDS 130.01 + FDRS 38.5.7 + Mazda IDS 131 - para VCM2 / J2534
IDS. IDS proporciona una cobertura completa de diagnóstico de vehículos a nivel de concesionario para todos los vehículos Ford, Lincoln y Mercury de 1996 a 2018 seleccionados. IDS requiere el uso de hardware de diagnóstico de Ford, incluidos los dispositivos VCM, VCM II y VCMM. La licencia del software IDS incluye el acceso temporal al software IDS, las actualizaciones de software y los archivos de calibración.
FJDS proporciona software de reprogramación de módulos que cubre desde 1996 hasta determinadas funciones de reprogramación de módulos Ford, Lincoln y Mercury 2018, además de un software completo de diagnóstico a nivel de concesionario para todos los vehículos Ford y Lincoln 2018 hasta la actualidad. El FJDS está diseñado para su uso con interfaces de comunicaciones de vehículos (VCI) compatibles con J2534, incluido el hardware de diagnóstico de Ford (VCM II o VCMM). La licencia de software FJDS incluye acceso basado en el tiempo al software FJDS, actualizaciones de software y archivos de calibración.
FDRS: software de diagnóstico de vehículos de fábrica de última generación de Ford Motor Company diseñado para su uso con VCI compatibles con VCM II, VCMM y J2534. FDRS proporciona una cobertura completa de diagnóstico de vehículos a nivel de concesionario para algunos vehículos de 2018 y futuros. FDRS proporciona capacidades superiores, es más fácil de usar y proporciona más herramientas de diagnóstico que IDS. El sistema basado en la nube garantiza que el técnico reciba el software más reciente cada vez que FDRS inicie sesión en la red de Ford.
¿Lo necesitas? Pulsadores Tasa (Reputación) y Gracias, PM por el pase.
Added Ford IDS 130.02
Added Ford IDS 130.03
Thanks given by: Carls , Carls
arbenit Offline
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 130.03 + FJDS 130.01 + FDRS 38.5.7 + Mazda IDS 131 - for VCM2 / J2534
