Latest news: ---- Tachosoft 23.1 + Activator Full ---- TIS 2000 + Dongle FULL ---- BMW ISTA+ 4.60.40 Standalone FULL ---- BMW ISTA 4.60.4x AND I-LEVEL OVERVIEW FULL ---- Navkal Pro ECM Programming With Activator ---- CNH Approval Password Generator + Keygen + Keymaker ---- John Deere Payload Encrpt Decrypt + Keygen + Full ---- BMW CAS 1,2,3,3+,4 FG FA TOOL FULL ---- RENAULT DDT2000 FILES COLLECTION MEGA ---- KIA HYUNDAI DTC EDITOR + KEYGEN ---- KIA Variant Codes Files Pack ---- BMW PSdZData 4.60.42 Files FULL ---- MAN KEY CATS TOOL ---- HYUNDAI KIA GDS SOFTWARE FULL ---- John Deere Service Advisor 5.3 2025 ---- HPT To BIN Converter + Keygen ---- MERCEDES SKCV CALC TOOL ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ---- WinOLS 4.7 Latest Version Update ---- KESS K-SUITE 2.48 Latest Version Update ---- Hello From USA ---- ETKA 8.6 International English 01.06.2025 Virtualbox ---- Vediamo 5.1.1 + Activator Tactrix OpenPort 2.0 Full ----
Added page, where you can pay with PayPal and immediately receive activation key to your email.
New update FullFixBySamik v4.7.2
- Added a fix for updating SDConnect C4 without a battery.
- Xentry login switcher has been removed, since now you no longer need to enter account data to work with an offline account.
- Removed the console window when starting Xentry.
- Minor fixes.
New update FullFixBySamik v5.0
- Updated Download Manager COMAND Hard-disc navigation v2.0.7.
- Optimized installation of DAS Standalone, DAS Special function, DAS Prototypes, DAS Offline flash, HHTWin, WisConfigurationTool, SW Finder, VGSNAG2 Manager and Unlock ECU.
- Automatic launch of ConfigAssist and Xentry Keygen after installation.
- Removed the console window during the XUS fix.
- Removed the restart prompt at the end of installation.
- Minor fixes.
Tested and working with Xentry 12.2023 final version.
Added automatic payment method for Russia.
New update FullFixBySamik v5.0.1
- Added activation key for WIS 2021.
- SeedCalc installation has been slightly optimized.
- Truck icons are no longer added to Xentry 12.2023.
- Added picture of AMG GT W590.
New update FullFixBySamik v5.1
- XENTRY Special Functions and DAS FDOK Keygens calculator has been updated from benjaminjai.
- Added a check to see if Xentry is installed on the system.
- The program automatically detects on which drive Xentry is installed and all programs that are installed in silent mode will be installed on the same drive.
- Fixed the Xentry Update Service icon in older versions of Xentry.
- Installation optimized.
- Provided that Xentry PassThru is installed on the system, the program will not create icons on Xentry SIM and Xentry AKT.
- Minor fixes.
New update FullFixBySamik v5.2
- Changed Xentry activation logic (thanks benjaminjai).
- Removed XENTRY Advanced Keygen! There is no longer any need to generate a key to activate Xentry in ConfigAssist.
- Added automatic activation of WIS 07.2021.
- Removed installation of WISConfigTool.
- Updated UnlockECU program.
- Updated icon for DAS Standalone and DAS Sim.
New update FullFixBySamik v6.0
- Added support for Daimler Truck Diagnostics.
- The logic of the C003 error fix has been completely changed. No need to modify Xentry system files! The old method did not always help, but the new method works 100%.
Attention!!! When you run Fix C003, all certificates are deleted from the system; if you imported certificates other than those in our fix, you will need to import them manually again!
- Also, the C003 error fix has been removed from the list of components; it will be installed along with the certificates.
- Now it doesn’t matter where Xentry is installed! You can even install it in the “J:\MyProgs\Diag\Merc\” folder and the fix will work with it.
- Removed the black window for adding folders to antivirus exceptions.
- The appearance of the component selection window has been changed, now it is much clearer and more convenient.
- The components themselves are shown depending on whether XDOS, XPT or S_DTPID is installed on the system. If Xentry is not installed at all, the associated components will not be displayed.
- If a specific adapter driver is installed on the system, it will also not be shown in the list of components.
- Added special functions to DAS for SMART SAM 450, 451, 452.
- At the end, when installing certificates, a window prompting you to restart the PC has been added.
- Icons of several programs have been updated (HHTWin, DAS Offline, VGSNAG2 Manager), Xentry Truck icons have also been updated (imported them from Daimler Truck Diagnostics).
- Remove PDF Center from autorun
- Monaco 9.02 has been added to the Monaco fix for working with SDConnect.
New update New update FullFixBySamik v6.1
- Added support for Daimler Truck Diagnostic Pass-Thru.
- Updated certificate import processes and fixed error C003. Now everything is more beautiful and intuitive.
- Changed the logic for disabling the online account window!
- Added removal of the list of Addons when printing to PDF in Xentry (thanks to sathack).
- When installing any version of Monaco, the request to update projects is automatically disabled in all versions that are installed on the system (thanks to sathack).
