Latest news: ---- hello from norway ---- Cummins Insite 9.3.0.22 Files Mega ---- SWFinder 6.1.8 File MEGA ---- ISTA iLean Voltage 4.61.40 No License No ISPI Admin Client ---- BMW ETK Price 10.2026 ---- Multi Editor Honda Tool Full ---- ECU Circuit Diagram Bosch Schematic ---- BMW FSC GENERATOR MG1 MD1 MSD DME TOOL ---- Wabco Calculator PIN1-PIN2 Activator Keygen ---- BMW Immo Off BTT EWS Deleter v1.1 Immobilizer TOOL ---- Alex Flasher + Keygen Full Version ---- Nexiq Etech 2.13 Setup File Needed ---- BMW ISTA Ilean 4.61.40 VOLTAGE PATCH TOOL ---- ATRIS Stahlgruber + Technik 2018 VM FULL ---- BMW ISTA VOLTAGE PATCH TOOL ---- Davinci 1.0.28 Unlocked Not Require Activation ---- Cnh Est 9.13 ---- Tuning Tool Tuner Calc UltraCuttr VMaxr InfoGrabbr Number ADDR QLaunchr ---- Xprog 5.55 ECU Programmer Tool ---- Multiprog Xhorse Patch FR Files ---- BOMAG EPC Wiring Diagram Service Manual FULL ---- JCB Service Master 4 v.1.24.5 Files MEGA ---- Nissan Consult 3+ J2534 VI2 VI3 VCI Files Full MEGA ---- MultiEcuScan 5.3 With KG Free For All ---- ECU TUNING SOLUTION FREE FOR ALL ---- Porsche PIWIS 4 Fix TOOL ---- Ford FJDS 133.01 + Patch Real Full ---- BMW ZGW CAN HACKER TOOL ---- BMW ISTA SQLiteDBs 4.58.30 PL MEGA ---- BMW ISTA GUI 2.1.0 New Update ----
BimmerLink 2.36.2 + BimmerCode 4.28.4 + BTool v3.4.5 Expert + BimmerUtility 1.14.07
(12-03-2023, 09:38 PM)botenzzi Wrote:
(08-18-2020, 10:57 AM)aleksey-ms Wrote: BimmerLink 2.33.0 + BimmerCode 4.21.8 + Bimmer BTool v3.4.5 Expert + 3.6.1 Lite  + BimmerUtility 1.14.07 for BMW (Android apk)
BimmerCode allows you to code the control units in your BMW or Mini to unlock hidden features and customize your car to your liking.
Activate the digital speed display in the instrument cluster or allow your passengers to watch videos while driving in the iDrive system. Do you want to disable the Auto Start/Stop function or the Active Sound Design? You will be able to code this and much more by yourself with the BimmerCode app.
!!! If you now install BimmerCode (new version), then NO version will work, the application (any version even 10 versions ago) works only for those who previously (on time) installed and updated the date from the server.
This is the situation with the update date, it’s probably been a year now: a new hacked version comes out, everything works and is updated, after about a week the official developer blocks the update date.
What to do? Wait for the new version to come out, install it immediately, update the date, and do not update (do not reinstall) unless absolutely necessary.
Supported cars
  • 1 Series 2008+
  • 2 Series, M2 2013+
  • 2 Series Active Tourer 2014+
  • 2 Series Gran Tourer 2015+
  • 3 Series, M3 2008+
  • 4 Series, M4 2013+
  • 5 Series, M5 2008+
  • 6 Series, M6 2008+
  • 7 Series 2008+
  • 8 Series 2018+
  • X1 2009+
  • X2 2018+
  • X3, X3 M 2010+
  • X4, X4 M 2014+
  • X5, X5 M 2008+
  • X6, X6 M 2008+
  • X7 2019+
  • Z4 2009+
  • i3 2013+
  • i8 2013+
  • Mini 2008+
  • Toyota Supra 2019+
[Image: BimmerCode.jpg]
Thanks pass. please
Thanks given by: raydem27
Added BimmerCode 4.21.9
Torzillas Offline
Contraseña please
Torzillas Offline
(08-18-2020, 10:57 AM)aleksey-ms Wrote: BimmerLink 2.33.0 + BimmerCode 4.21.9 + Bimmer BTool v3.4.5 Expert + 3.6.1 Lite + BimmerUtility 1.14.07 para BMW (Android apk)
BimmerCode le permite codificar las unidades de control de su BMW o Mini para desbloquear funciones ocultas y Personaliza tu coche a tu gusto.
Active la visualización digital de velocidad en el grupo de instrumentos o permita que sus pasajeros vean videos mientras conducen en el sistema iDrive. ¿Quiere desactivar la función de inicio/parada automática o el diseño de sonido activo? Podrás codificar esto y mucho más tú mismo con la aplicación BimmerCode.
!!! Si ahora instala BimmerCode (nueva versión), entonces NINGUNA versión funcionará, la aplicación (cualquier versión, incluso hace 10 versiones) funciona solo para aquellos que previamente (a tiempo) instalaron y actualizaron la fecha desde el servidor.
Esta es la situación con la fecha de actualización, probablemente ya haya pasado un año: sale una nueva versión pirateada, todo funciona y se actualiza, después de aproximadamente una semana el desarrollador oficial bloquea la fecha de actualización.
¿Qué hacer? Espere a que salga la nueva versión, instálela inmediatamente, actualice la fecha y no actualice (no reinstale) a menos que sea absolutamente necesario.
Coches compatibles
  • 1 Serie 2008+
  • Serie 2, M2 2013+
  • Serie 2 Active Tourer 2014+
  • Serie 2 Gran Tourer 2015+
  • Serie 3, M3 2008+
  • Serie 4, M4 2013+
  • Serie 5, M5 2008+
  • Serie 6, M6 2008+
  • Serie 7 2008+
  • Serie 8 2018+
  • X1 2009+
  • X2 2018+
  • X3, X3M 2010+
  • X4, X4 M 2014+
  • X5, X5 M 2008+
  • X6, X6 M 2008+
  • X7 2019+
  • Z4 2009+
  • i3 2013+
  • i8 2013+
  • Mini 2008+
¿Necesito? Pulsadores Calificar (Reputación) y Gracias , PM por gracias
GRACIAS pase porfavor
Coches compatibles
  • 1 Serie 2008+
  • Serie 2, M2 2013+
  • Serie 3, M3 2008+
  • Serie 4, M4 2013+
  • Serie 5, M5 2008+
  • Serie 6, M6 2008+
  • Serie 7 2008+
  • Serie 8 2018+
  • X1 2009+
  • X2 2018+
  • X3, X3M 2010+
  • X4, X4 M 2014+
  • X5, X5 M 2008+
  • X6, X6 M 2008+
  • X7 2019+
  • Z4 2009+
  • i3 2013+
  • i8 2013+
  • Mini 2008+
Thanks given by: Torzillas
Torzillas Offline
Y lo hice ...lo haré de nuevo..
No te llegan mis mensajes?? Soy nuevo no sé si estoy haciendo algo mal.
Gracias
(12-30-2023, 11:48 AM)Torzillas Wrote: Y lo hice ...lo haré de nuevo..
Gracias
Push buttons Rate (Reputation) and Thanks (if it done)
write me p/m for pass (if it done too) please just wait, i'll send it
radioman Offline
Thanks
(01-09-2024, 11:38 PM)radioman Wrote: Thanks
U'r welcome, friend !
Thanks given by: Hmurconr , Hmurconr
Autogru Offline
PASS PLEASE!!!!
