Latest news: ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ---- VCM EDITOR COLLECTION FULL ---- VCDS Release 26.3.0 VIIPlus Loader 08.026.08 FULL ---- Winols 4.7 With Installer Full Mega ---- BMW CAS4+ EDITOR TOOL FULL ---- BMW ISTA 4.61.1x VERSION AND I-LEVEL OVERVIEW ---- ProSeCco Data Time Tool Full ---- CDA 6-J2534 bridge (Dubb45 Tool to use CDA with Passthru) ---- Subaru SSM4 Universal J2534 + Patch Full ---- Xentry Full Fix 4.9.8 Soft Easiest Installation Activation ---- Diagbox 7.57 Pack Complete Full ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 + Fix Last Update ---- GM ECU FLASHER TOOL FULL ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ---- BMW ISTA Czech Database 4.57.XX 4.61.XX MEGA ---- BMW ISTA+ 4.61.1x Files MEGA ---- BMW ISPI ISTA LAUNCHER 1.61.02.2059 MEGA ----
OBDeleven 0.92.0 (phone diagnostics)
OBDeleven is the software version for the OBDeleven device. OBDeleven is an intelligent diagnostic tool designed to understand and improve the performance of your vehicle. It works with the cloud-based Android car software and provides full access to your car, allowing you to read, delete, share faults, monitor, program and activate various comfort functions.
I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.
[Image: OBDeleven1.jpg] [Image: OBDeleven2.jpg]
Thanks given by: Torzillas , Torzillas , sahin11 , audi13
Added OBDeleven 0.71.0
Added OBDeleven 0.75.0 (phone diagnostics)
Added OBDeleven 0.77.0
Added OBDeleven 0.79.0
Added OBDeleven 0.80.0
OBDeleven 0.91.0
OBDeleven 0.92.0
