ECM Titanium 1.61 + WinOLS 4.51 (VMware)
Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
Questions about the password, write in a personal.
Asking for a password in a topic will be ignore.
[Image: e03ba2a746f69bdbc183e264e8f32f53.jpg]
ECM Titanium Original from AlienTech is a program for interpreting and editing engine control unit firmware files. ECM Titanium allows you to work with firmware easily, conveniently, independently and with high reliability. By purchasing the original product, you will get all the widest possibilities and convenience when editing firmware for electronic control units from the industry leader. Regularly released updates and functionality expansion. This is the choice of professionals!
A feature of ECM Titanium is "drivers", software modules that convert firmware parameters into a structure that is easy to understand. The parameters are divided into categories (air management, injection system, turbocharging ...), in which there are real parameters for calibration - increasing engine power and reducing fuel consumption.
[Image: 070e94782e30155e716038c49c496bbb.jpg]
WinOLS. The WinOLS program is designed for chip tuning software. The program allows you to independently calibrate the electronic control units of various cars. For example, in its arsenal is an increase in torque, engine power of a car, and a reduction in fuel consumption. All these calibrations can now be performed not only by professionals, but also by ordinary motorists.
serigle06 Offline
 pass please?
serigle06 Offline
pass please?
voldemaras Offline
Reikia? Spauskite mygtukus  Įvertinkite (Reputacija)  ir  Ačiū , PM (rašykite privačiomis žinutėmis) už praėjimą.
Klausimus dėl slaptažodžio rašykite asmenine žinute.
Slaptažodžio prašymas temoje bus ignoruojamas. ECM Titanium Original iš AlienTech
WinOLS. WinOLS programa skirta mikroschemų derinimo programinei įrangai. Programa leidžia savarankiškai sukalibruoti įvairių automobilių elektroninius valdymo blokus. Pavyzdžiui, jo arsenale yra padidintas sukimo momentas, automobilio variklio galia ir sumažintos degalų sąnaudos. Visus šiuos kalibravimus dabar gali atlikti ne tik profesionalai, bet ir paprasti vairuotojai.
 praleisti prašau?
hi pasword
Changing the archive content and password. For those partners who downloaded before 12/02/2023, you need to download again and do these steps again. After you click button Rep (Reputation) + Thanks on the thread, i will send you a password.
didiwicos Offline
Please send me PW for ECM Titaniun THX Dieter
