Latest news: ---- Injector Statics Dynamics Calculator Tool ---- WinOLS Organizer Automatic Tool ---- Bosch MD1CS TPROT Bypass Tool ---- BMW EDC16 EEPROM TOOL ---- Deutz-Fahr Tractors Factory Service Workshop Manuals ---- Ksuite 2.25 Clones Kess 5.017 Ktag 7.020 ---- ODIS Service 7.2.1 Multilang VAS5054A 6154 Passthru J2534 Win10 ---- HITACHI ALLINONE TOOL 3.9.0.0 MPDR 3.22 MEGA ---- VAG BMW MB OPEL PEUGEOT EDC17 FILES MEGA ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ----
VmWare AutoData 3.45 Last FREE FOR ALL
AutoData 4.35 Last in VMWare Win7Pro 32bit FREE FOR ALL
    Size 19GB total, 7GB archive (WinRAR)  No passwords needed!
AutoData 4.35 is a program for car services, includes information on auto repair, repair interval with a list of works, diagnostic data, lubricants and their volumes, electrical circuits, working diagrams.
Including data: Conditioners.  ABS. Belts, chains and timing gears. Engine management systems, component testing. Engine management. Control unit connectors. Key programming. Service indicators.
In general, this is exactly the program that any service station needs!
A virtual machine with a preinstalled program is a convenient tool for solving a necessary task.
The program is already installed and configured, no additional time and knowledge is required for tuning and optimization, you just turn on the Virtual Machine and work!
Best regards, SerJ-R !
Main windows:
[Image: 1-Main-Windows.png]
Program start and version:
[Image: 2-Program-Start.jpg]
Program work:
[Image: 3-Car-select.jpg]
[Image: 4-Data-Category-Choose.jpg]
[Image: 5-Tech-Data.jpg]
[Image: 6-Repair-Times.jpg]
[Image: 7-Wheel-Aligment.jpg]
[Image: 8-Timing-Belt.jpg]
[Image: 9-Service-Illustrations.jpg]
[Image: 10-Service-Shedules.jpg]
If you use my products, "Thanks" and "Reputation" are the best rewards!
dodge1977 Offline
It is not working, it says E0209 Sentinel key not found.
Thanks given by: bookini
(10-04-2021, 01:30 PM)dodge1977 Wrote: It is not working, it says E0209 Sentinel key not found.
Thanks!  I will check it on another PC and fix, if need.
a86anton Offline
Hi all.
Hi all.
I found the solution to the sentinel problem.
You must follow the steps to install the "SentinelDriver" program, and when it asks you if you can modify / repair / uninstall, choose the repair mode.
After restart it will work.
Thanks!
dodge1977 Offline
Hi all.
Hi all.
Thanks!
Where can we found " progit
Where can we found the "SentinelDriver" program ?
Yes I see onto many people have a problem with this VM.
I will correct this and re-upload VM again in some days.
Best regards
(10-10-2021, 07:13 AM)batya303 Wrote: Nagyon köszönöm és várom, de azt is tisztázni kell, hogy intel vagy amd host környezetben készült -e, mivel az illesztőprogram módosításai zavaróak lehetnek !!
My PC is Intel SkyLake I9  based, not AMD.
Virtual Machine is updated! Please try to use onto your PC! Best regards, Sergey!
dodge1977 Offline
Now it is good working, very good job.
Thank you.
Thanks given by: Prodrive , bookini , bookini
FILAT_TR Offline
Hello. Can you pls update link?
10 Guest(s)
