Latest news: ---- maxxforce files ---- Hitachi MPDr v3.9 Full ---- DTS Monaco 9 + Keygen + Patch + Projects 2022 Full ---- WINOLS VIDEO TUNING TUTORIAL PACKAGE ---- DAS FDOK WIS STANDALONE SEED KEY CALCULATOR KEYGEN ---- Diagbox 9.91 VM Activated Full ---- Evolic Renault Dacia ECU Tool ---- Vediamo 5.01.01 + Openport + Level 10 Full ---- Zenzefi Aftersales Certificate 23.11.2026 + 07.10.2026 + 26.08.2026 ROOT BACKEND ---- PCR2.1 DECODER TOOL FULL ---- DTS Monaco Projects 9.02 Files MEGA ---- Volvo Devtool Developer + Keygen Full ---- ODIS-E Flash Data 04.2024 FULL ---- Nissan Consult 73.20 Programming Data 71.40 Full ---- MULTI TOOL EC15P FULL ---- PCM Tuner PCM Flash 1.2.7 Activated ---- Synaptic Remover Tool Full ---- Case SR220 SR250 SV250 SV300 Service Repair Manual ---- Hello! ---- Tachosoft 23.1 + Activator Full ---- TIS 2000 + Dongle FULL ---- BMW ISTA+ 4.60.40 Standalone FULL ---- BMW ISTA 4.60.4x AND I-LEVEL OVERVIEW FULL ---- Navkal Pro ECM Programming With Activator ---- CNH Approval Password Generator + Keygen + Keymaker ---- John Deere Payload Encrpt Decrypt + Keygen + Full ---- BMW CAS 1,2,3,3+,4 FG FA TOOL FULL ---- RENAULT DDT2000 FILES COLLECTION MEGA ---- KIA HYUNDAI DTC EDITOR + KEYGEN ---- KIA Variant Codes Files Pack ----
New update FullFixBySamik v6.2
- Added program 7G SCN by Samik.
- Added key for WIS 07.2021 to 12.12.2025.
- Fixed a bug from v6.1 related to the offline login window in Xentry 2021.
- Also in Xentry 2021 there was no removal of ConfigAssist autorun, it was also added in this version.
- Added a "Close" button after successfully importing certificates.
- Added driver for Chinese Openport 2.0.
Thanks given by: X431 , X431
New update FullFixBySamik v6.4.3
- The 7G SCN by Samik program has been updated.
- Fixed the SW Finder database.
- Updated Download Manager for downloading maps.
- Configured launch of WIS 07.2021 from Daimler Truck.
- Added a fix for SDConnect in Daimler Truck Platform Independent Diagnostics.
FullFixBySamik v6.4.1
- Fixed a bug from the previous version regarding the installation of ToolKit.
- Added a fix for opening WIS 07.2021 from Xentry.
- Updated DB in 7G SCN by Samik.
FullFixBySamik v6.4
- Added a fix for SDConnect to work with Xentry 03.2024.
- Fixed a small bug with DAS Sim when Xentry was NOT installed on the C drive.
FullFixBySamik v6.3
- XUS has been updated, now the database is from 02/05/2024 with 135,681 files (thanks to Linkov).
- Added a small fix for working with Xentry 03.2024.
- Fixed the problem with installing the VCX SE, VXDiag driver if Xentry is not installed on drive "C".
- Fixed problem installing VCX SE, VXDiag driver in Daimler Truck Diagnostics.
- Fixed a bug where the installation gave a syntax error if Xentry was not installed on the system.
- Functions related to WIS Standalone have been removed, since they were no longer relevant on new versions of Xentry. But WIS activation itself still occurs when Xentry is activated.
- Added a new certificate for diagnostics.
nano.113 Offline
can i set up a virgin key whit this fix? or there is a chance to scn components? i need to set up a new key because my mb doesnt have or someone that codes remotely?
9 Guest(s)
