Latest news: ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ----
Jaguar Land Rover JLR SDD 166 2025 - Torrent File
Carsoftcar Online
Land Rover
Jaguar Land Rover JLR SDD 166  - Torrent File
Questions about the password, write in a personal.
Asking for a password in a topic will be ignore.
[Image: fba0b2c28849abed5fa4fe936e0be97b.png]
Year / Release date: 02.2025
Version: 166
System requirements: windows 7 - 11 x86 x64
Interface language: Multilingual
Description:  SDD supports 2007-2016 JLR models.
Additional information: If you want me to do the installation, setup and activation personally, Write me a private message.
Activation instruction with a complex activator:
1) Install vcredist2005_x86
2) Install SDD_166.00.exe
3) For Windows x64, run cmd (Command Prompt as administrator) and type: mklink /D "C:\Program Files\ JLR" "C:\Program Files (x86)\JLR"
4) Without closing the command line, point to the patch.bat file and run it
5) Edit C:\Program Files\JLR\SDD\SDD\app.properties and C:\Program Files\JLR\IDS\SDD\ app.properties and add the following lines to the end of the file:
      sdd.authentication.topix.address = http: //asdaswq.re
      sdd.windows10.enabled = true
      sdd.ie11.enabled = true
6) Run jlr sdd from the desktop
7) Restart Edge in Internet Explorer mode
8) The window shows that the topic is not available. Click "Continue"
9) paste any username and continue
    Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
voldemaras Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739545200]
Rep (Reputation) + Thanks
send password
arbenit Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739718000]
Carsoftcar Online
Land Rover
