Latest news: ---- MULTI TOOL EC15P FULL ---- PCM Tuner PCM Flash 1.2.7 Activated ---- Synaptic Remover Tool Full ---- Case SR220 SR250 SV250 SV300 Service Repair Manual ---- Hello! ---- Tachosoft 23.1 + Activator Full ---- TIS 2000 + Dongle FULL ---- BMW ISTA+ 4.60.40 Standalone FULL ---- BMW ISTA 4.60.4x AND I-LEVEL OVERVIEW FULL ---- Navkal Pro ECM Programming With Activator ---- CNH Approval Password Generator + Keygen + Keymaker ---- John Deere Payload Encrpt Decrypt + Keygen + Full ---- BMW CAS 1,2,3,3+,4 FG FA TOOL FULL ---- RENAULT DDT2000 FILES COLLECTION MEGA ---- KIA HYUNDAI DTC EDITOR + KEYGEN ---- KIA Variant Codes Files Pack ---- BMW PSdZData 4.60.42 Files FULL ---- MAN KEY CATS TOOL ---- HYUNDAI KIA GDS SOFTWARE FULL ---- John Deere Service Advisor 5.3 2025 ---- HPT To BIN Converter + Keygen ---- MERCEDES SKCV CALC TOOL ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ----
Hino Diagnostic eXplorer 2 (DX2) 2022, (DX3) 12.2025 and Hino EPC Truck Japan 2018
hino
Hino Diagnostic eXplorer 2 (DX2) 2022, (DX3) 12.2025 and Hino EPC Truck Japan 2018 - Remote Install
Hino Diagnostic eXplorer 2 (DX2) 2021 - $80
Hino Diagnostic eXplorer 3 (DX3) 2022 - $100
Hino Diagnostic eXplorer 3 (DX3) 1.23.7 09.2023 - $130
Hino Diagnostic eXplorer 3 (DX3) 1.25.9 12.2025 - $175
Hino EPC Truck Japan 2018 - $65
[Image: images?q=tbn:ANd9GcR9qmSlcXh5kj5zMWZR-hk...k&usqp=CAU]
The HINO Diagnostic explorer DX3 is a tool equipped with all the functions needed to diagnose trouble, check functions, and configure the settings of the electronic systems built into HINO engines.
This tool covers the following markets
– US markets. USA, Japan, Russia and others.
– RUS, DEF, JPN, USA. UU., CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TN, GBR, IRL, SGP, THA.
BENEFITS DXI HINO HINO Low speed DXI contact with large amounts of data, not to expand the functionality of the software, led to the need to develop a new diagnostic system.
From 2015 to diagnose HINO vehicles introduced in the work of the next generation system.
Main functions
– Acquires and deletes trouble data.
– Warps the trouble codes read from the ECU to workflow sequences corresponding diagnostic and directly displays the required data diagnosis.
– obtains conditions when vehicle sensor problems (freeze frame function) occur.
– Monitors the sensors and actuators equipped on the engine (monitor function data) and test the operation of the solenoid valves to force operating them (Active Test function).
– Simulates diagnostic work with only a PC (Simulation function).
– Automatically saves the data from the ECU and analyzes the problems based on the stored data even when you can not understand the cause of the problems.
Full customization capability
– Turn the system off Motor protection
– Set the maximum vehicle speed
– Set the maximum speed cruise control
– Set idle speeds of fixed and variable TDF
– Change Injector Calibration QR Code when replacing injectors
– the supply pump relearning when replacing SCV or supply pump
– complete test capability and regeneration of the DPF
– Help menus built for troubleshooting specific diagnostics
Hino EPC Truck
An electronic catalog of spare parts for trucks of Japanese assembly, which have a right-hand drive.
hino
Hino Diagnostic eXplorer 3 (DX3) 1.23.9 10.2023 - $200
hino
Hino Diagnostic eXplorer 3 (DX3) 1.24.1 01.2024 - $200
Hino Diagnostic eXplorer 3 (DX3) 1.25.1 12.2024
hino
