Latest news: ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ---- Automatic Transmission Repair Manuals Rebuild Parts ---- BMW ISPI ISTA Launcher Offline Version MEGA ---- Bosch ESI [tronic] 2014 DVD1+DVD2+DVD3 Diagnostic Software ---- L-Suite Checksum Tool 1.03 Full Pack With KSuite DLLs ---- Actia Multidiag J2534 PassThru Support Full ---- hello from norway ---- Cummins Insite 9.3.0.22 Files Mega ---- SWFinder 6.1.8 File MEGA ---- ISTA iLean Voltage 4.61.40 No License No ISPI Admin Client ---- BMW ETK Price 10.2026 ---- Multi Editor Honda Tool Full ---- ECU Circuit Diagram Bosch Schematic ---- BMW FSC GENERATOR MG1 MD1 MSD DME TOOL ---- Wabco Calculator PIN1-PIN2 Activator Keygen ---- BMW Immo Off BTT EWS Deleter v1.1 Immobilizer TOOL ---- Alex Flasher + Keygen Full Version ---- Nexiq Etech 2.13 Setup File Needed ---- BMW ISTA Ilean 4.61.40 VOLTAGE PATCH TOOL ---- ATRIS Stahlgruber + Technik 2018 VM FULL ---- BMW ISTA VOLTAGE PATCH TOOL ---- Davinci 1.0.28 Unlocked Not Require Activation ---- Cnh Est 9.13 ----
Radio Code Database Last Update
VAG Calculator (Volkswagen, Audi, Skoda, Seat): This is based on a database of serial numbers. Currently, there  are 660,000 serials loaded.
Philips Calculator: Based on a database of over 14 million codes for various car radio units made by Philips. I've added checkboxes so you can search for your radio code according to the serial number prefix.
Grunding Calculator: This is based on a database of over 7 million codes, containing radio codes for many Grunding radio units installed in various car brands.
Renault/Dacia Calculator: This database allows you to calculate the radio code according to the last 4 digits of the serial number, called the precode (e.g., A100).
Ford Calculator: Currently supports only V and M series with a full database for these series.
Toyota ERC: Based on an algorithm, with improvements to be added in the near future.
Becker Calculator: Based on an algorithm and a database, it supports 4 types of units: 4-digit units, 4-button units, 6-button units, and 8-button units.
GM Database: According to the VIN number, you can get the radio code, key code, IMMO code, and alarm code. It is not a full database yet, currently containing 509,000 VIN numbers.
Chrysler Mode: Based on an algorithm and a database, it supports 4 types of units that can be decoded at this moment.
Fiat: Currently, it can only calculate codes for DIIACI units.
PSA, Fiat, VP1, VP2, Delco CDR2005, and CDR500 for serials starting with GM02051, GM0205X, GM0205Y, GM15001, GM1500X, GM1500Y.
Additional Codes: 1200 new VAG codes have been added.
Bug Fixes: Some minor bugs have been resolved.now all calculators open in same window
TomServis Offline
(05-07-2025, 07:54 PM)Prodrive Wrote: Poslední aktualizace databáze rádiových kódů
password ?
38
I already found it, sorry for the comment
