Latest news: ---- Haynes Pro 2018 Virtual Box Full Mega ---- Komatsu manuals, anyone can share? ---- TOOL32 SERVICE HISTORY WITH EDIABAS EXTENSION ---- Introduktion ---- PCM Flash 1.20 Cleaned No Virus ---- PACCAR ESA COMPLETE + KEYGEN + SW FILES FULL ---- VCDS 25.3.2 + VIIPluslоader STM Arm ---- DTC Toyota Lexus Firmware Editor English ---- XENTRY 09.2026 FILES FULL ---- Immo Doctor v2.1.1 Full ---- How to Read an Electrical Schematic A Step by Step Guide ---- Tool32 Service History Generator Full ---- Hello from sweden ---- Automotive Software Complete With KG Collection Full ---- ToyoLex 3 + KG New Update ---- Renault Can Clip 237 Full Installation + KG 2024 ---- JLR PATHFINDER BOOK TRICKS AND SECRETS BOOK ---- Toyota Immo Remover Tool Full ---- MPPS 18 Clone ECU Remapping Software FULL ---- Chinese truck EOL fault codes ---- Sinotruk Automatic transmission training course ---- HardCut QLaunchr UtraCuttr HotStartr TunerCalc Vmaxr InfoGrabbr Collection Full ---- BMW ISTA Standalone 4.45 + Ediabas 7.3 FULL ---- Mitsubishi MUT3-III SE PassThru J2534 SEPN ---- DaVinci Deluxe 2025 Real Work ---- JCB Servicemaster 25.1.0 Fully Unlocked With Keygen ---- Zenzefi After Sales STANDARD 2026.11.23 ---- KT200 Offline Dongle KT200II FULL ---- Honda HDS 3.105.036 + i-HDS 1.009.001 New 2026 ---- BMW SQLiteDBs EN 4.60.30 NEW UPDATE ----
Jeep - Chrysler - Dodge IMMO Tools (APNT + AEMT-Maxx + Chysler v3)
lfas Offline
Jeep
AEMT-MAXX IMMO Tool J2534 (2005/2022)
AEMT MAXX official website:
Cost 90$ AEMT MAXX is a tool that evolved from an early SKIM and VIN tool developed by ECUunlock.
The tool allowed the user to make a SKIM-activated PCM into a SKIM-desactivated PCM.
_Supported ECU Types From 1995 to 2008 Model.
SCI ECU, JTEC, SBEC, NGC1, NGC2, NGC3, CUMMINS
Disable SKIM: IMMO OFF
SRI Mileage Edit: Modify the Service Reminder Indicator mileage.
VIN Editor: Edit Vehicle Identification Numbers.
Read Memory: Access and read flash memory.
Write Memory: Write data back to the flash memory.
_ Supported CAN BUS Systems From 2005 to 2021 Models.
NGC3, NGC4, NGC4A, GPEC, GPEC2, GPEC2A, GPEC3, CUMMINS
Read EPROM: Read data from EPROM.
Write EPROM: Write data back to EPROM.
Write Memory: Write flash memory data efficiently.
_______________________
APNT Chrysler IMMO OFF J2534 (2005/2019)
Cost 60$, use it with J2534 devices,
to edit the SKIM security and VIN change.
APNT functions: (chrysler-dodge-jeep)
- READ ECU INFO
- SKIM DISABLE
- SRI MILEAGE EDIT
- VIN EDITOR
** for gas ecu's 1995-2019
** for diesel from 1998 -2013
list supported ecu's:
( siemans and cummins ecu's support vin read and write only )
make sure your j2534 device supports sci ( j2610 ) and can bus before purchase
apnt is benchtop programming tool.
(most use it in vehicle with no issues. i can not guarantee it supports all in vehicle programming )
apnt will disable skim but!!! if you install ecu into a vehicle with a skim module it will re-enable skim in that vehicle . you will need to unplug skim module if you are using for this purpose.
Be careful:
if you unplug the skim module to disable skim you will lose keyless entry and tire pressure monitor functionality.
To Watch APNT VIDEO, Click Here
Chrysler Tool v3.0 for VIN change, Cost 30$
Antena Vatansever, Kalibre (24lc16)
Anten Cherokee (MCU 9S12DB128 eeprom)
RFH V1 Joumey 2011+, Şarj Cihazı, 300M (MCU 9S12EXQ384 eeprom)
TIPGW Cherokee (MCU 9S12DT256 eeprom)
Compu Motorola V1'in hafızası var (95320)
Compu Motorola Memoria 195080)
Compu Motorola Memoria 2(95080)
RFH V2 Grand Cherokee, Durango (MCU 9S12EXQ384 eeprom)
RFH V3 Pusula (MCU 9S12EXQ384 eeprom)
RFH V4 Dart (MCU 9S12EXQ384 eeprom)
RFH V5 2017+ (95640)
Bilgisayar Motorola V2 hafızalı (95320)
BCM RAM SPC5606B (D-FLAŞ)
[Image: Chrysler-IMMO-Off-v3.0.png]
Price for the 3 software is only 120$ if it's needed.
B.REGRADS
Thanks given by: jgdf
Jem@prog Offline
(06-13-2025, 05:01 PM)lfas Wrote: AEMT-MAXX IMMO Tool J2534 (2005/2022)
- READ ECU INFO
- SKIM DISABLE
- SRI MILEAGE EDIT
- VIN EDITOR
Be careful:
B.REGRADS
Hello is this available please
autorepair Offline
i have the newest one ecu villan 2.0 if intrested pm me
Jem@prog Offline
(12-17-2025, 11:15 PM)autorepair Wrote: i have the newest one ecu villan 2.0 if intrested pm me
Can it turn off Skim in a NGC3 2006 Dodge Dakota?
