Latest news: ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ----
Hino Diagnostic eXplorer 3 (DX3) 06.2026, (DX2) 2022 and Hino EPC Truck Japan 2018
hino
Hino Diagnostic eXplorer 3 (DX3) 06.2026, (DX2) 2022 and Hino EPC Truck Japan 2018 - Remote Install
Hino Diagnostic eXplorer 2 (DX2) 2021 - $80
Hino Diagnostic eXplorer 3 (DX3) 2022 - $100
Hino Diagnostic eXplorer 3 (DX3) 1.23.7 09.2023 - $130
Hino Diagnostic eXplorer 3 (DX3) 1.26.3 06.2026 - $199
Hino EPC Truck Japan 2018 - $65
[Image: images?q=tbn:ANd9GcR9qmSlcXh5kj5zMWZR-hk...k&usqp=CAU]
The HINO Diagnostic explorer DX3 is a tool equipped with all the functions needed to diagnose trouble, check functions, and configure the settings of the electronic systems built into HINO engines.
This tool covers the following markets
– US markets. USA, Japan, Russia and others.
– RUS, DEF, JPN, USA. UU., CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TN, GBR, IRL, SGP, THA.
BENEFITS DXI HINO HINO Low speed DXI contact with large amounts of data, not to expand the functionality of the software, led to the need to develop a new diagnostic system.
From 2015 to diagnose HINO vehicles introduced in the work of the next generation system.
Main functions
– Acquires and deletes trouble data.
– Warps the trouble codes read from the ECU to workflow sequences corresponding diagnostic and directly displays the required data diagnosis.
– obtains conditions when vehicle sensor problems (freeze frame function) occur.
– Monitors the sensors and actuators equipped on the engine (monitor function data) and test the operation of the solenoid valves to force operating them (Active Test function).
– Simulates diagnostic work with only a PC (Simulation function).
– Automatically saves the data from the ECU and analyzes the problems based on the stored data even when you can not understand the cause of the problems.
Full customization capability
– Turn the system off Motor protection
– Set the maximum vehicle speed
– Set the maximum speed cruise control
– Set idle speeds of fixed and variable TDF
– Change Injector Calibration QR Code when replacing injectors
– the supply pump relearning when replacing SCV or supply pump
– complete test capability and regeneration of the DPF
– Help menus built for troubleshooting specific diagnostics
Hino EPC Truck
An electronic catalog of spare parts for trucks of Japanese assembly, which have a right-hand drive.
hino
Hino Diagnostic eXplorer 3 (DX3) 1.23.9 10.2023 - $200
hino
Hino Diagnostic eXplorer 3 (DX3) 1.24.1 01.2024 - $200
Hino Diagnostic eXplorer 3 (DX3) 1.25.1 12.2024
hino
Hino Diagnostic eXplorer 3 (DX3) 1.25.9 12.2025
hino
