Latest news: ---- DTSProjects for DTS 9.04.016 ---- DTS 9.04.016 FULL PATCH ---- GM TIS2000 NAO Virtual Machine New Update ---- DRB III Emulator Virtual Machine New Update ---- Bosch ECU Database v0.3 Tool ---- ZenZefi After Sales Standard Valid Until 2027.02.17 ---- EDC17 IMMO SERVICE TOOL ---- Davinci Deluxe 1.0.XX.0 Full ---- MULTI EDITOR BY DR SALEH FULL ---- Zenzefi Aftersales Certificate 17.02.2027 + 26.11.2026 ---- Lsuite Checksum Tool Full ---- Kubota Service Manuals (FSM) Collection ---- DTS Monaco 8.16.015 Install + Patch + Keygen FULL ---- Multi Editor Honda 1.39.1.0.0 Full ---- Clone OpenPort 2.0 Windows 11 Driver ---- FTAG Checksums Test Fix TOOL ---- DTS Monaco 9.02 Install + Patch + Keygen FULL ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ---- Renault Can Clip 222 RTL2002 + Patch Full ---- Xentry Cars Passthru OpenShell 09.2026 Xus Das Wis Epc Starfinder Vediamo Monaco ---- VAG IMMO OFF TOOL NEW UPDATE ---- PCMflash Dongle Manager New Update ---- BMW Voltage Monitor TOOL ---- Global TechStream GTS+ Software ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ----
KSUITE 2.80 NEW VERSION
Prodrive Offline
Advantage Of 2.80 :
- Add more car models
- Remove Bugs
- Reduce 80% Wake Up Error
- Fix Checksum Error
- Fix RSA Error
- Fix Unmatched Key Error
- Pcr2.1 Unlock Corrected
- OBD2 edc15v edc15p edc15vm No Problem
- Writing without problems At edc17 VAG
- Optimize Running Speed
- EU Online Version
KESS V5.017 support
- It supports More 140 Protocols Than the HW V4.036 KESS.
- You can use it Online and it will not damage the hardware.
- SW support multi-languages:English, German, Spanish, Italian, Portuguese, French
- KESS V4.036 no token limited for some car, has token limited for some other car.
- KESS V5.017 has no token limited for all vehicles !
- Working System: Windows XP Professional /Win7 / Win 8/ Win 10
- With coverage of all major brands and protocols including Line, CAN, EDC17 and MED17 and for Ford J1850. KSuite V2 is everything you need to work as a successful tuner at      a very affordable price.
- Read and write ECU via OBD2 port directly, no need disassemble ECU from the car, easy to use
