Latest news: ---- GM ECU FLASHER TOOL FULL ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ---- BMW ISTA Czech Database 4.57.XX 4.61.XX MEGA ---- BMW ISTA+ 4.61.1x Files MEGA ---- BMW ISPI ISTA LAUNCHER 1.61.02.2059 MEGA ---- DASH CALCULATOR TOOL FULL ---- Fiat MultiEcuscan 5.3 - 2024 ---- ISUZU SERVICE REPAIR MANUAL PACKAGE ---- Odis-S 25.3.0 + Odis-E 21.0.1 Full 08.2026 ---- XENTRY 09.2026 RELEASE 4 FILES ---- Can Clip 221 Tactrix OpenPort PassThru + Keygen Full ---- CAS-2 Editor 3.1 Tool FULL ---- PORSCHE ENGINE 2.9 BITURBO WIRING DIAGRAM ---- MB 7G.SCN Coding Data Collection Offline Programming ---- PCM Flash Dongle Drivers J2534 FULL ---- All Cars Pin Diagram Tool Full ---- Hello, let me introduce myself. ---- Hello ----
citroen c1 auto box config
stevec1 Offline
Citroen
i am trying to do a a re-learn on a citroen c1 semi auto gearbox, apart from using the diagbox software, can anyone recommend another program to do the re-learning after the clutch replacement, delphi does not give me the option and i dont currently have the hardware box for the psa diagbox software.
thanks
Thanks given by: Galenot , RidgecokS , fabry7768 , Shaikh , Nidzoba , hoschi001
dyann10123 Offline
Hello this method work without diagnostic system, all manually, but sorry i have only the document in french:
- mettre en position 'N'
- couper le contact
- il faut shunter les contact TC (13) et CG (4) de la prise obd
diagnostic
- attendre 10 secondes minimum
- mettre le contact
- enfoncer la pédale de frein au moins 7 fois en 3 secondes
- un signal sonore retentit 2 fois espacés de 0.25s
- avec le levier de vitesse : composez les séquences suivantes avec le pied maintenu enfoncé sur le frein.
initialisation de l'ECU :
N E M - M - M - M - E N
initialisation de l'embrayage :
N E M + M - M + M - E N
initialisation de la boîte de vitesse :
N E M - M - M + M + E N
- relâcher le frein
- enfoncer le frein une fois
- le signal sonore retentit ( intervalle de 2.5s entre chaque
réglage ou initialisation).
initialisation de l'ECU : deux bip espacés de 0.5s
initialisation de l'embrayage : trois bis espacés de 0.5s
initialisation de la boîte de vitesse : quatre bips espacés de 0.5s
Si vous n'entendez pas les bips : recommencez 15s au moins après avoir coupé le contact.
- pour finir : enfoncer la pédale de frein 3 fois dans un lap de 2s
- deux bips espacés de 0.25s retentissent
- couper le contact et attendre 10s
- débrancher le shunt
Thanks given by: Rafai999 , daryn41
