Latest news: ---- WEBASTO DIAGNOSTIC WTT V3.8 NEW UPDATE ---- PCMflash Dongle Emulator V0.1.2 For Versions 1.2.0 And 1.2.1 ---- BMW Standard Tools 2.12 FULL ---- BMW CIC Patcher v2 Generate Your Retrofit FSC Certificates ---- MB SeedKey Generator Complete Software ---- BMW ISTA 4.62.2x VERSION I-LEVEL OVERVIEW ---- TOYOTA LEXUS TUNER V2 FULL ---- PCMflash 1.2.0 - 1.2.1 Dongle Security TOOL ---- DTSProjects for DTS 9.04.016 ---- DTS 9.04.016 FULL PATCH ---- GM TIS2000 NAO Virtual Machine New Update ---- DRB III Emulator Virtual Machine New Update ---- Bosch ECU Database v0.3 Tool ---- ZenZefi After Sales Standard Valid Until 2027.02.17 ---- EDC17 IMMO SERVICE TOOL ---- Davinci Deluxe 1.0.XX.0 Full ---- MULTI EDITOR BY DR SALEH FULL ---- Zenzefi Aftersales Certificate 17.02.2027 + 26.11.2026 ---- Lsuite Checksum Tool Full ---- Kubota Service Manuals (FSM) Collection ---- DTS Monaco 8.16.015 Install + Patch + Keygen FULL ---- Multi Editor Honda 1.39.1.0.0 Full ---- Clone OpenPort 2.0 Windows 11 Driver ---- FTAG Checksums Test Fix TOOL ---- DTS Monaco 9.02 Install + Patch + Keygen FULL ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ---- Renault Can Clip 222 RTL2002 + Patch Full ---- Xentry Cars Passthru OpenShell 09.2026 Xus Das Wis Epc Starfinder Vediamo Monaco ----
ISTA 4.29.15 / SQLiteDBs (OTHER,en,de,zh,ru,it) 4.29.14 / BLP 4.29.11 / SDP 4.29.11
serigle06 Offline
BMW
Description: ISTA + (Rheingold ISTA-D): BMW Dealer Diagnostic Software * Rejection of fake FSC can be disabled in ISTAGUI.exe.config, active by default. * permission can be changed in ISTAGUI.exe.config file * you can disable CheckSystemRequirements in ISTAGUI.exe.config * enable programming with ENET is now possible in ISTAGUI.exe.config (at your own risk). * You can now enable diagnostics for J29 (Toyota Supra) in ISTAGUI.exe.config. * "Unknown terminal voltage!" the message with ENET is corrected, now ISTA does check the voltage, but does not display it. * reading FASTA data from vehicle is disabled in ISTAGUI.exe.config * if you are using my Regfiles, open it with Notepad and change InstallLocation to the correct location on her PC. (not required with installer) + Standard Tools Installer (Ediabas, INPA, NCS Expertentool etc. ECU and SGDAT updated with v68.0) - SP-Daten v68.0.800 + PSdZData Lite -4.24.31 -4.25.40 -4.26.35 -4.27.31 -4.28.41 -4.29.11 + Tools
Thanks given by: lussy , lussy , robertmane , robertmane
